[mapserver-users] CGI Tilemode blank on one layer
Daniel Mwaurah
mwaurah at gmail.com
Wed Dec 23 14:29:42 PST 2015
Thats true Steve,
Its actually rendering in the non tiled setting. I wonder how come its one
layer not rendering in tilemode while the other one is. Both render ok in
non tile setting.
On Wed, Dec 23, 2015 at 10:29 PM, Lime, Steve D (MNIT) <
Steve.Lime at state.mn.us> wrote:
> It will look at the extent of shapefiles to decide if it needs to process
> features in a layer but that’s to be expected. I mean, if there’s nothing
> to draw then why bother. Have you verified that the layers render in a
> non-tiled setting?
> *From:* Daniel Mwaurah [mailto:mwaurah at gmail.com]
> *Sent:* Wednesday, December 23, 2015 3:26 PM
> *To:* Lime, Steve D (MNIT) <Steve.Lime at state.mn.us>
> *Cc:* mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] CGI Tilemode blank on one layer
> Thank you Steve for your response.
> I have tried commenting out the extents but still the same problem. I
> think it recognizes the inbuilt extents of the data layers.
> On Wed, Dec 23, 2015 at 9:36 PM, Lime, Steve D (MNIT) <
> What happens if you comment out the layer extents? They really shouldn’t
> be necessary.
> *From:* mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] *On
> Behalf Of *Daniel Mwaurah
> *Sent:* Wednesday, December 23, 2015 2:27 PM
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* [mapserver-users] CGI Tilemode blank on one layer
> hallo people,
> I would greatly appreciate some help with Mapserver Tile mode. Eeven a
> hint in the right direction would be much appreciated. I am trying to
> display two layers in Tile mode in open layers as follows
> 1.
> http://localhost/cgi-bin/mapserv?MAP=/var/wpsinput/gdss.map&layer=kenyaoutline&mode=tile&tile=${x}+${y}+${z}.png
> <http://localhost/cgi-bin/mapserv?MAP=/var/wpsinput/gdss.map&layer=kenyaoutline&mode=tile&tile=$%7bx%7d+$%7by%7d+$%7bz%7d.png>
> 2.
> http://localhost/cgi-bin/mapserv?MAP=/var/wpsinput/gdss.map&layer=10m_ocean&mode=tile&tile=${x}+${y}+${z}.png
> <http://localhost/cgi-bin/mapserv?MAP=/var/wpsinput/gdss.map&layer=10m_ocean&mode=tile&tile=$%7bx%7d+$%7by%7d+$%7bz%7d.png>
> The problem arises in that one layer the 10m_ocean displays while the
> other one just shows a blank. I suspect it has to do with the extents
> because the 10m_ocean layers has a large extent from -180 to 180 while the
> kenyaoutline layer only covers one country from about 33 to 37 degrees.
> Is there a limitation to small extents in tile mode? or what could be the
> problem. My mapfile is as below.
> MAP
> #FONTSET "[fontsetpath]"
> DEBUG 5
> CONFIG "MS_ERRORFILE" "/var/www/wpsinput/ms_error.txt"
> EXTENT 33 -5 42 6
> IMAGETYPE "png"
> NAME "Natural_Earth_quick_start_for_QGIS"
> SIZE 600 600
> CONFIG ON_MISSING_DATA "LOG"
> STATUS ON
> UNITS DD
> OUTPUTFORMAT
> NAME "png"
> MIMETYPE "image/png"
> DRIVER "AGG/PNG"
> EXTENSION "png"
> IMAGEMODE RGBA
> TRANSPARENT TRUE
> END # OUTPUTFORMAT
> PROJECTION
> "proj=longlat"
> "datum=WGS84"
> "no_defs"
> END # PROJECTION
> LEGEND
> KEYSIZE 20 10
> KEYSPACING 5 5
> LABEL
> SIZE MEDIUM
> OFFSET 0 0
> SHADOWSIZE 1 1
> TYPE BITMAP
> END # LABEL
> STATUS OFF
> END # LEGEND
> QUERYMAP
> SIZE -1 -1
> STATUS OFF
> STYLE HILITE
> END # QUERYMAP
> SCALEBAR
> INTERVALS 4
> LABEL
> SIZE MEDIUM
> OFFSET 0 0
> SHADOWSIZE 1 1
> TYPE BITMAP
> END # LABEL
> SIZE 200 3
> STATUS OFF
> UNITS MILES
> END # SCALEBAR
> WEB
> FOOTER ""
> HEADER ""
> TEMPPATH ""
> METADATA
> "ows_onlineresource" "
> http://localhost/cgi-bin/mapserv?map=/home/wpsinput/worldmap.map"
> "ows_enable_request" "*"
> "ows_srs" "EPSG:4326"
> "ows_title" "Natural_Earth_quick_start_for_QGIS"
> END # METADATA
> #TEMPLATE "[templatepath]"
> END # WEB
> LAYER
> DATA "/var/www/10m_physical/10m_ocean.shp"
> EXTENT 33 -5 42 6
> METADATA
> "ows_title" "10m_ocean"
> END # METADATA
> NAME "10m_ocean"
> PROJECTION
> "proj=longlat"
> "datum=WGS84"
> "no_defs"
> END # PROJECTION
> STATUS ON
> TILEITEM "location"
> TYPE POLYGON
> UNITS METERS
> CLASS
> NAME "Single symbol"
> STYLE
> COLOR 198 226 242
> END # STYLE
> END # CLASS
> END # LAYER
> LAYER
> DATA "/var/www/kenyaoutline/Kenyaoutline.shp"
> EXTENT 33 -5 42 6
> METADATA
> "ows_title" "Kenyaoutline"
> END # METADATA
> NAME "Kenyaoutline"
> PROJECTION
> "proj=longlat"
> "datum=WGS84"
> "no_defs"
> END # PROJECTION
> STATUS ON
> TILEITEM "location"
> TYPE POLYGON
> UNITS METERS
> CLASS
> STYLE
> COLOR 0 0 0
> END # STYLE
> END # CLASS
> END # LAYER
> END # MAP
> The same happens when i try to view it using QGIS Tilelayer plugin.
> Kind regards,
> Mwaura Daniel
> Kind regards,
> Mwaura Daniel
Kind regards,
Mwaura Daniel
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20151223/c00f2c53/attachment-0001.html>
