[mapserver-users] How to enable GetFeatureInfo in MS4w 3.0.6 ?
Bistrais, Bob
Bob.Bistrais at maine.gov
Tue Jun 9 12:36:55 PDT 2015
Got it!
Thanks Jeff!
-----Original Message-----
From: Jeff McKenna [mailto:jmckenna at gatewaygeomatics.com]
Sent: Tuesday, June 09, 2015 2:26 PM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] How to enable GetFeatureInfo in MS4w 3.0.6 ?
On 2015-06-09 2:37 PM, Bistrais, Bob wrote:
> I can't seem to find the answer to this one. I have a number of WMS
> layers which I would like to enable GetFeatureInfo. I am using MS4W
> 3.0.6. I can't seem to get the GetFeatureInfo to work. Can somebody
> point me to a reference?
I always follow the WMS Server document, when I configure a mapfile for GetFeatureInfo (see the section "Configuring for GetFeatureInfo Requests" at http://www.mapserver.org/ogc/wms_server.html). I check it often for syntax.
Key points as noted there, are:
- set your WEB METADATA parameter of "wms_feature_info_mime_type"
(likely to "text/plain")
- in the LAYER METADATA specify the fields to expose through "gml_include_items"
- set DUMP TRUE inside the layer
- set CLASS TEMPLATE (likely to something like "dummy.html")
If I missed something it's likely inside that document.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
