[mapserver-users] no result with getFeatureInfo text/plain
Jörg Thomsen
jt at mapmedia.de
Wed Jun 10 07:48:53 PDT 2015
Hello Jukka,
it is definitely a feature. It's nice to define different outputs, all
items for text/plain an only a formatted subset in html.
But wouldn't it be nice too, if we only had to configure it in the
header with an overwrite-option in the layer-section?
Jörg
Am 10.06.2015 um 16:26 schrieb Rahkonen Jukka (MML):
> Hi,
> You must have either "wms_include_items" or "ows_include_items" in the LAYER-METADATA. Now you have only "gml_include_items" at LAYER level. You do have "ows_include_items" at MAP level but it does not have any effect there. On the other hand, "ows_include_items" does not have any effect on the text/html output but that can only be adjusted by editing the template. For sending out the same information with text/plain and text/html the Mapserver admin must make edits in two different places - ows_include_items and the template. I am not sure if this should be considered as a bug or a feature but at least it is confusing.
> Tested with Mapserver 7.0-beta1.
> -Jukka Rahkonen-
> Jörg Thomsen wrote:
>> Hello,
>> in my WMS getFeatureInfo works fine with info_format html [1] and gml, but I don't get a result with text/plain [2]. And I found similar a example on mapserver.org... [3] & [4].
>> Why does getFeaturInfo for text/plain not work?
> [1]
> http://geoportal.luckau.de/ows/flaechennutzungsplaene?VERSION=1.1.1&REQUEST=GetFeatureInfo&SERVICE=WMS&LAYERS=FNP10_Grenze&QUERY_LAYERS=FNP10_Grenze&WIDTH=650&HEIGHT=450&SRS=EPSG:25833&BBOX=392406,5730396.807692308,434593,5759603.192307692&STYLES=&FORMAT=image/png&INFO_FORMAT=text/html&EXCEPTIONS=application/vnd.ogc.se_xml&X=369&Y=359&FEATURE_COUNT=100&
> [2]
> http://geoportal.luckau.de/ows/flaechennutzungsplaene?VERSION=1.1.1&REQUEST=GetFeatureInfo&SERVICE=WMS&LAYERS=FNP10_Grenze&QUERY_LAYERS=FNP10_Grenze&WIDTH=650&HEIGHT=450&SRS=EPSG:25833&BBOX=392406,5730396.807692308,434593,5759603.192307692&STYLES=&FORMAT=image/png&INFO_FORMAT=text/plain&EXCEPTIONS=application/vnd.ogc.se_xml&X=369&Y=359&FEATURE_COUNT=100&
> [3]
> http://demo.mapserver.org/cgi-bin/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&BBOX=-11.332970,24.121208,47.584718,57.965035&SRS=EPSG:4326&WIDTH=1001&HEIGHT=575&LAYERS=cities&STYLES=&FORMAT=image/png&TRANSPARENT=true&QUERY_LAYERS=cities&INFO_FORMAT=text/plain&X=229&Y=280
> [4]
> http://demo.mapserver.org/cgi-bin/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&BBOX=-11.332970,24.121208,47.584718,57.965035&SRS=EPSG:4326&WIDTH=1001&HEIGHT=575&LAYERS=cities&STYLES=&FORMAT=image/png&TRANSPARENT=true&QUERY_LAYERS=cities&INFO_FORMAT=text/html&X=229&Y=280
> Jörg
> and here's my mapfile:
>> WEB
>> IMAGEPATH '/tmp/'
>> IMAGEURL '/tmp/'
>> METADATA
>> 'ows_title' 'Flächennutzungsplan der Stadt Luckau und seinen Ortsteilen'
>> 'ows_onlineresource' 'http://geoportal.luckau.de/ows/flaechennutzungsplaene'
>> 'ows_srs' 'EPSG:4326 EPSG:25832 EPSG:25833 EPSG:325833 EPSG:4528 EPSG:4839'
>> 'ows_abstract' 'WMS-Dienst zur Dartellung von Flächennutzungspläne im Stadtgebiet Luckau mit seinen Ortsteilen'
>> 'ows_accessconstraints' 'none'
>> 'ows_fees' 'none'
>> 'ows_keywordlist' 'Luckau, Flächennutzungspläne, WMS'
>> 'ows_include_items' 'all'
>> 'ows_encoding' 'ISO-8859-1'
>> 'WMS_FEATURE_INFO_MIME_TYPE' 'text/html'
>> 'gml_include_items' 'all'
>> include './includes/contact_information.inc.map'
>> END
>> END
>> ### Layer ####
>> LAYER
>> NAME 'FNP01_Grenze'
>> CLASS
>> NAME 'plan_grenze'
>> STYLE
>> SYMBOL 0
>> width 3
>> OUTLINECOLOR 0 0 255
>> #COLOR 220 54 199
>> END
>> END
>> DATA 'raster/fnp_luckau/grenzen_umring/plan_01_grenze.shp'
>> METADATA
>> 'ows_title' 'FNP 01 Grenze'
>> 'ows_abstract' 'Umring Flächennuntzungsplan Luckau, Teil 1, Kümmritz, Uckro, Paserin'
>> 'ows_srs' 'EPSG:4326 EPSG:25833 EPSG:325833 EPSG:4528 EPSG:4839'
>> "gml_include_items" "all"
>> "gml_featureid" "ID"
>> "ows_enable_request" "*"
>> END
>> STATUS ON
>> PROJECTION
>> "init=epsg:325833"
>> END
>> TYPE POLYGON
>> DUMP true
>> HEADER './templates/fnp_legende_header.html'
>> TEMPLATE './templates/fnp_legende.html'
>> FOOTER './templates/footer.html'
>> END
> mapserver-users at lists.osgeo.org
