[mapserver-users] Is this a CGI problem?
TDS tds at tds-net.de
Fri Jun 12 07:21:40 PDT 2015
YesNo :-/
https://trac.osgeo.org/grass/ticket/1730
Similar:
http://stackoverflow.com/questions/137773/what-does-the-no-version-information-available-error-from-linux-dynamic-linker/156387#156387
The problem is that you have a mixture of library version on your
system, e.g. installed GDAL by packagemanager and later compiled
yourself - on in /usr/lib and on in /usr/local/lib
You can try to remove the other libraries via package manager. So you
have only your compiled libraries later.
Bye, Mathias
mailto:tds at tds-net.de
1+1=10
You have a question? - 42 or RTFM.
Am 12.06.2015 um 16:07 schrieb Gery:
> vielen Dankl! Thanks a lot for that, I just added your tips and I got a new
> error message, this time related to gdal:
> apache log:
> [Fri Jun 12 09:10:06.316827 2015] [cgi:error] [pid 6680] [client
> 127.0.0.1:41157] AH01215: GDAL: In GDALDestroy - unloading GDAL shared
> library.
> also the same appears with shp2img:
> shp2img: /usr/local/lib/libgdal.so.1: no version information available
> (required by /usr/lib/x86_64-linux-gnu/libmapserver.so.1)
> GDAL: In GDALDestroy - unloading GDAL shared library.
> test.png is empty. I have installed gdal-1.11.2 from source, mapserv -v
> gives:
> mapserv: /usr/local/lib/libgdal.so.1: no version information available
> MapServer version 6.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML
> SUPPORTS=PROJ SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO
> SUPPORTS=SVG_SYMBOLS SUPPORTS=RSVG SUPPORTS=ICONV SUPPORTS=FRIBIDI
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
> SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
> Is there a way to fix this without uninstalling and/or reinstalling gdal?
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Is-this-a-CGI-problem-tp5210276p5210648.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150612/2938dd71/attachment.html>
