[mapserver-users] Odd warning in WFS GetCapabilities ~ what's missing in the config?
Passmore, James H.
jpass at bgs.ac.uk
Thu Mar 12 05:12:21 PDT 2015
I have a MapServer version 6.4.1 service set-up and was looking at the WFS GetCapabilities response:
http://194.66.252.155/cgi-bin/BGS_OGE_Bedrock_and_Surface_Geology_in2/ows?service=WFS&request=GetCapabilities&
All my FeatureTypes have the following warning:
WARNING: Mandatory mapfile parameter: (at least one of) MAP.PROJECTION, LAYER.PROJECTION or wfs/ows_srs metadata was missing in this context.
The WFS is working though as far as I can see, for example, I get features when loading in QGIS.
Is this a bug or have I got something wrong in the config?
MAP.PROJECTION is set as:
MAP
CONFIG "PROJ_LIB" "C:/.../gisinternals/bin/proj/SHARE"
CONFIG "MS_ERRORFILE" "C:/.../OGE2/ms_error.log"
CONFIG "PGEO_DRIVER_TEMPLATE" "DRIVER=Microsoft Access Driver (*.mdb, *.accdb);DBQ=%s"
CONFIG "OGR_SKIP" "ODBC"
EXTENT -8.7 49.8 1.8 60.9
PROJECTION
#Default service projection
"init=epsg:4326"
END
LAYER.PROJECTION (for example for GE.GeologicFault.BGS.EN.1M.Surface) is set as:
LAYER
NAME GE.GeologicFault.BGS.EN.1M.Surface
EXTENT -8.01697 49.9678 0.715821 60.8368
PROJECTION
"init=epsg:4326"
END
In addition I have:
WEB
METADATA
"OWS_SRS" "CRS:84 EPSG:27700 EPSG:3034 EPSG:4258 EPSG:4326"
and:
LAYER
METADATA
"OWS_EXTENT" "-8.01697 49.9678 0.715821 60.8368"
"WFS_OWS" "EPSG:4326"
Thanks
James Passmore
GIS and WWW Specialist
British Geological Survey,
Environmental Science Centre,
KEYWORTH,
United Kingdom,
NG12 5GG
Linked Data (vCard):http://data.bgs.ac.uk/ref/BritishGeologicalSurvey
w3w:http://w3w.co/firmly.legs.craftsmen
Phone:+44 (0)115 936 3125
Fax:+44 (0)115 936 3200
jpass at bgs.ac.uk
http://www.bgs.ac.uk/
Skype:BGSjames
@nmtoken
This message (and any attachments) is for the recipient only. NERC is subject to the Freedom of Information Act 2000 and the contents of this email and any reply you make may be disclosed by NERC unless it is exempt from release under the Act. Any material supplied to NERC may be stored in an electronic records management system.
