[mapserver-users] Odd warning in WFS GetCapabilities ~ what's missing in the config?
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu Mar 12 06:56:43 PDT 2015
Hi Jukka,
I never do use 1.1.0 :)
But please do let the reporter (James) know.  Thanks,
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2015-03-12 10:41 AM, Rahkonen Jukka (MML) wrote:
> Hi Jeff,
> If you use &version=1.1.0 you'll see the warnings:
> http://194.66.252.155/cgi-bin/BGS_OGE_Bedrock_and_Surface_Geology_in2/ows?service=WFS&request=GetCapabilities&VERSION=1.1.0
> -Jukka-
> Jeff McKenna wrote:
> On 2015-03-12 9:12 AM, Passmore, James H. wrote:
>> I have a MapServer version 6.4.1 service set-up and was looking at the WFS GetCapabilities response:
>> All my FeatureTypes have the following warning:
>> WARNING: Mandatory mapfile parameter: (at least one of) MAP.PROJECTION, LAYER.PROJECTION or wfs/ows_srs metadata was missing in this context.
>> The WFS is working though as far as I can see, for example, I get features when loading in QGIS.
>> Is this a bug or have I got something wrong in the config?
>> MAP.PROJECTION is set as:
>> MAP
>>       CONFIG "PROJ_LIB" "C:/.../gisinternals/bin/proj/SHARE"
>>       CONFIG "MS_ERRORFILE" "C:/.../OGE2/ms_error.log"
>>       CONFIG "PGEO_DRIVER_TEMPLATE" "DRIVER=Microsoft Access Driver (*.mdb, *.accdb);DBQ=%s"
>>       CONFIG "OGR_SKIP" "ODBC"
>>       EXTENT -8.7 49.8 1.8 60.9
>>       PROJECTION
>>           #Default service projection
>>           "init=epsg:4326"
>>       END
>> LAYER.PROJECTION (for example for GE.GeologicFault.BGS.EN.1M.Surface) is set as:
>>       LAYER
>>           NAME GE.GeologicFault.BGS.EN.1M.Surface
>>           EXTENT -8.01697 49.9678 0.715821 60.8368
>>           PROJECTION
>>               "init=epsg:4326"
>>           END
>> In addition I have:
>>           WEB
>>                   METADATA
>>                           "OWS_SRS" "CRS:84 EPSG:27700 EPSG:3034 EPSG:4258 EPSG:4326"
>> and:
>>       LAYER
>>                   METADATA
>>                       "OWS_EXTENT" "-8.01697 49.9678 0.715821 60.8368"
>>                    "WFS_OWS" "EPSG:4326"
>> Thanks
>> James Passmore
>> GIS and WWW Specialist
>> British Geological Survey,
>> Environmental Science Centre,
>> KEYWORTH,
>> United Kingdom,
>> NG12 5GG
>> Linked Data (vCard):http://data.bgs.ac.uk/ref/BritishGeologicalSurvey
>> w3w:http://w3w.co/firmly.legs.craftsmen
> You are missing the required parameter VERSION in your request.  If I add it to your request I get no warnings:
> http://194.66.252.155/cgi-bin/BGS_OGE_Bedrock_and_Surface_Geology_in2/ows?service=WFS&request=GetCapabilities&VERSION=1.0.0
> (hello from 'across the big pond')
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services http://www.gatewaygeomatics.com/
