[mapserver-users] display only one district
Steve.Toutant at inspq.qc.ca Steve.Toutant at inspq.qc.ca
Fri Mar 20 12:13:20 PDT 2015
In other threads of this list, it was suggested to use a subquery in DATA
instead of using FILTER, when postgis is used as a datasource.
http://mapserver.org/fr/input/vector/postgis.html#data-access-connection-method
If you want to use only one mapfile than runtime variable substitution can
be used
Carlos Ruiz <boolean10001 at yahoo.com>@lists.osgeo.org
Envoyé par : mapserver-users-bounces at lists.osgeo.org
2015-03-20 14:53
Veuillez répondre à
A
rishi <rishe28 at gmail.com>, "jmckenna at gatewaygeomatics.com"
<jmckenna at gatewaygeomatics.com>, "mapserver-users at lists.osgeo.org"
<mapserver-users at lists.osgeo.org>
cc
Objet
Re: [mapserver-users] display only one district
Rishi,
>From a MAP file approach, you can use the FILTER tag inside of the LAYER
section:
FILTER [string]
This parameter allows for data specific attribute filtering that is done
at the same time spatial filtering is done, but before any CLASS
expressions are evaluated. For OGR and shapefiles the string is simply a
mapserver regular expression. For spatial databases the string is a SQL
WHERE clause that is valid with respect to the underlying database.
For example: FILTER ([type]=?road? and [size]<2)
In a static way, you will need to have two MAP files (one without FILTER
and another with FILTER) and you have to configure each project to point
to the right MAP file.
Mtro. Carlos Ruiz
To: jmckenna at gatewaygeomatics.com; "mapserver-users at lists.osgeo.org"
Sent: Friday, March 20, 2015 6:43 AM
Subject: [mapserver-users] display only one district
Hi all
Iam using Postgres database to diasplay districts on the google map
It is working.
But now i want to display only one district instead of 50.
In my database there are 50 districts data, but i want to display only
one.
And also i have to use the same mapfile in to 3 projects, in one project
all the districts has to be displayed and in one project only one district
has to be display.
How to do this
plz send me the code
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150320/7e890fa9/attachment.html>
