[mapserver-users] Newbie problem: mapfile for wgs84 based on epsg:28992
TallDragon talldragon at hotmail.com
Wed Mar 25 06:53:08 PDT 2015
Sorry, but after weeks of reading and trying solutions, I really need some
help. I have a shapefile in RD New Amersfoort. I understand that there are a
lot of problems with the conversion, however my mapserver output is empty
and stays empty for weeks now.
Can someone please get me in the right direction for this? My map file is
MAP
  NAME           EHAM
  IMAGETYPE      PNG
  EXTENT         4.70774 52.28803 4.80941 52.36267
  SIZE           1400 900
  SHAPEPATH      "/var/maps/eham"
  IMAGECOLOR     255 255 255
  PROJECTION
    "init=epsg:4326"
  END
#  TRANSPARENT ON
  CONFIG "MS_ERRORFILE" "/home/andre/log/mapserv.txt"
      LAYER # Groen
    NAME         groenvoorziening
    DATA         groen
    STATUS       ON
    TYPE         POLYGON
    PROJECTION
      "init=epsg:28992"
    END
    METADATA
        "wms_srs" "EPSG:28992 EPSG:4326"
    END
#    PROJECTION
#      "proj=sterea"
#      "lat_0=52.15616055555555"
#      "lon_0=5.38763888888889"
#      "k=0.9999079"
#      "x_0=155000"
#      "y_0=463000"
#      "ellps=bessel"
#      "units=m"
"towgs84=565.2369,50.0087,465.658,-0.406857330322398,0.350732676542563,-1.8703473836068,4.0812"
#      "no_defs"
#    END
    CLASS
      NAME       GROEN
      STYLE
        COLOR        232 232 232
        OUTLINECOLOR 32 32 32
      END
    END
  END # States polygon layer ends here
END
the call to
http://localhost/cgi-bin/mapserv?map=eham.map&mode=map&layer=groen gives an
empty map
View this message in context: http://osgeo-org.1560.x6.nabble.com/Newbie-problem-mapfile-for-wgs84-based-on-epsg-28992-tp5195384.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
