[mapserver-users] RE Mapserver 7 make error
Even Rouault even.rouault at spatialys.com
Tue May 5 07:04:47 PDT 2015
Le mardi 05 mai 2015 15:53:51, Steve.Toutant at inspq.qc.ca a écrit :
> Cairo version is 1.8 on my centos6.5 distro, and the system admin won't
> let me update it
> Just not using mapserver from the distro was a hard fight....
Several options :
- bribe your sys admin
- upgrade to centos 7
- install a centos 7 VM within the centos 6.5
- bundle a more recent cairo alongside with mapserver, in a non system
directory
- edit mapserver sources to use the older enum values (if that tricks actually
works)
> Even Rouault <even.rouault at spatialys.com>
> 2015-05-05 09:20
> A
> mapserver-users at lists.osgeo.org
> cc
> Objet
> Re: [mapserver-users] RE Mapserver 7 make error
> Le mardi 05 mai 2015 15:13:34, Steve.Toutant at inspq.qc.ca a écrit :
> > Any hint on what can I do about that Cairo error when compiling mapserv?
> > Thank you
> Steve,
> you need to upgrade to a more recent version of cairo. Perhaps 1.10 or
> 1.12.
> I think Thomas mentionned to me that it might be possible to use older
> cairo
> by using older names for the CAIRO_OPERATOR_xxxx values. I think we
> discussed
> that in a github ticket (not sure), but can't find it anymore.
> Even
> > Steve Toutant/INSPQ/SSSS
> > 2015-05-01 15:11
> > A
> > cc
> > Objet
> > I'm compiling MS7 on Centos 6.5. I get an error running make
> > make
> > Scanning dependencies of target mapserver
> > [  0%] Building C object CMakeFiles/mapserver.dir/fontcache.c.o
> > [  1%] Building C object CMakeFiles/mapserver.dir/cgiutil.c.o
> > [  2%] Building C object CMakeFiles/mapserver.dir/mapgeos.c.o
> > [  2%] Building C object CMakeFiles/mapserver.dir/maporaclespatial.c.o
> > [  3%] Building C object CMakeFiles/mapserver.dir/mapsearch.c.o
> > [  4%] Building C object CMakeFiles/mapserver.dir/mapwms.c.o
> > [  4%] Building C object CMakeFiles/mapserver.dir/classobject.c.o
> > [  5%] Building C object CMakeFiles/mapserver.dir/mapgml.c.o
> > [  6%] Building C object CMakeFiles/mapserver.dir/mapoutput.c.o
> > [  6%] Building C object CMakeFiles/mapserver.dir/mapwmslayer.c.o
> > [  7%] Building C object CMakeFiles/mapserver.dir/layerobject.c.o
> > [  8%] Building C object CMakeFiles/mapserver.dir/mapgraticule.c.o
> > [  8%] Building C object CMakeFiles/mapserver.dir/mapows.c.o
> > [  9%] Building C object CMakeFiles/mapserver.dir/mapservutil.c.o
> > [ 10%] Building C object CMakeFiles/mapserver.dir/mapxbase.c.o
> > [ 10%] Building C object CMakeFiles/mapserver.dir/maphash.c.o
> > [ 11%] Building C object CMakeFiles/mapserver.dir/mapowscommon.c.o
> > [ 11%] Building C object CMakeFiles/mapserver.dir/mapshape.c.o
> > [ 12%] Building C object CMakeFiles/mapserver.dir/mapxml.c.o
> > [ 13%] Building C object CMakeFiles/mapserver.dir/mapbits.c.o
> > [ 13%] Building C object CMakeFiles/mapserver.dir/maphttp.c.o
> > [ 14%] Building C object CMakeFiles/mapserver.dir/mapparser.c.o
> > [ 15%] Building C object CMakeFiles/mapserver.dir/mapstring.c.o
> > [ 15%] Building C object CMakeFiles/mapserver.dir/mapxmp.c.o
> > [ 16%] Building C object CMakeFiles/mapserver.dir/mapcairo.c.o
> > /opt/geomatique/src/mapserver/mapcairo.c: In function âms2cairo_compopâ:
> > /opt/geomatique/src/mapserver/mapcairo.c:809: erreur:
> > âCAIRO_OPERATOR_MULTIPLYâ undeclared (first use in this function)
> > /opt/geomatique/src/mapserver/mapcairo.c:809: erreur: (Each undeclared
> > identifier is reported only once
> > /opt/geomatique/src/mapserver/mapcairo.c:809: erreur: for each function
> it
> > appears in.)
> > /opt/geomatique/src/mapserver/mapcairo.c:811: erreur:
> > âCAIRO_OPERATOR_SCREENâ undeclared (first use in this function)
> > /opt/geomatique/src/mapserver/mapcairo.c:813: erreur:
> > âCAIRO_OPERATOR_OVERLAYâ undeclared (first use in this function)
> > /opt/geomatique/src/mapserver/mapcairo.c:815: erreur:
> > âCAIRO_OPERATOR_DARKENâ undeclared (first use in this function)
> > /opt/geomatique/src/mapserver/mapcairo.c:817: erreur:
> > âCAIRO_OPERATOR_LIGHTENâ undeclared (first use in this function)
> > /opt/geomatique/src/mapserver/mapcairo.c:819: erreur:
> > âCAIRO_OPERATOR_COLOR_DODGEâ undeclared (first use in this function)
> > /opt/geomatique/src/mapserver/mapcairo.c:821: erreur:
> > âCAIRO_OPERATOR_COLOR_BURNâ undeclared (first use in this function)
> > /opt/geomatique/src/mapserver/mapcairo.c:823: erreur:
> > âCAIRO_OPERATOR_HARD_LIGHTâ undeclared (first use in this function)
> > /opt/geomatique/src/mapserver/mapcairo.c:825: erreur:
> > âCAIRO_OPERATOR_SOFT_LIGHTâ undeclared (first use in this function)
> > /opt/geomatique/src/mapserver/mapcairo.c:827: erreur:
> > âCAIRO_OPERATOR_DIFFERENCEâ undeclared (first use in this function)
> > /opt/geomatique/src/mapserver/mapcairo.c:829: erreur:
> > âCAIRO_OPERATOR_EXCLUSIONâ undeclared (first use in this function)
> > make[2]: *** [CMakeFiles/mapserver.dir/mapcairo.c.o] Erreur 1
> > make[1]: *** [CMakeFiles/mapserver.dir/all] Erreur 2
> > make: *** [all] Erreur 2
> > I do have cairo and cairo-devel installed (1.8.8-3.1.el6).
> > How can I fix this?
> > Thanks you
http://www.spatialys.com
