[mapserver-users] static versus shared obj memory use
Richard Greenwood richard.greenwood at gmail.com
Fri May 15 14:51:32 PDT 2015
Got it! Thanks for that explanation, it makes much more sense to me now.
Rich
On Fri, May 15, 2015 at 3:39 PM, Andy Colson <andy at squeakycode.net> wrote:
> "how many processes" is not very descriptive.  How many mapserve's vs how
> many different execuable.  Many mapserv's will share, but they wont share
> with any other executables.
> ogr/gdal might be a good example.  You have ogr compiled into mapserv.
> Running many mapserv's will all share the same code page in ram. However
> ogrinfo, ogr2ogr, etc wont be able to share with mapserv.
> -Andy
> On 5/15/2015 4:34 PM, Richard Greenwood wrote:
>> Thanks for the reply Andy. I had Googled a bit and found this
>> stackoverflow
>> http://stackoverflow.com/questions/2649334/difference-between-static-and-shared-libraries
>> discussion in which the answer at the bottom said:
>>     "The most significant advantage of shared libraries is that there is
>>     only one copy of code loaded in memory, no matter how many processes
>>     are using the library. For static libraries each process gets its
>>     own copy of the code. This can lead to significant memory wastage."
>> But I'm not sure if that's applicable with a web/fcgi application.
>> rich
>> On Fri, May 15, 2015 at 3:04 PM, Andy Colson <andy at squeakycode.net
>> <mailto:andy at squeakycode.net>> wrote:
>>     On 5/15/2015 3:59 PM, Richard Greenwood wrote:
>>         I'm working on Linux and have statically linked mapserv for
>>         convenience
>>         but now I'm wondering if it is adversely affecting memory use. For
>>         example, if I have five fcgi mapserv instance like:
>>             mapserv.fcgi?map=mapfile1.map
>>             mapserv.fcgi?map=mapfile2.map
>>             mapserv.fcgi?map=mapfile3.map
>>             mapserv.fcgi?map=mapfile4.map
>>             mapserv.fcgi?map=mapfile5.map
>>         Am I using more memory with my static build than if they all
>>         referencing
>>         the shared libmapserver.so?
>>         Thanks,
>>         rich
>>     I believe you will pay for the cost of one executable, the others
>>     will share the code pages, but get their own data pages.
>>     So no, you probably are not using more memory using static build.
>>     -Andy
>> Richard W. Greenwood, PLS
>> www.greenwoodmap.com <http://www.greenwoodmap.com>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150515/15ab3d80/attachment-0001.html>
