[mapserver-users] [EXTERNAL] Re: Mapserver 7+oracle - wfs getFeature with filter on numeric field
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Tue May 19 12:14:43 PDT 2015
I made some tests with SQL*Plus. I took a row which has an attribute "nro" which is of type REAL and the value with my Finnish locale looks like "42.071". I suggest you, Steve, to repeat this simple test.
SQL> select nro from test_table where nro=42,071;
[ERROR on row 1]:
ORA-00933: [SQL-command did not end correctly]
Another test:
SQL> select nro from test_table where nro=42.071;
       NRO
    42,071
Notice that even if the result is printed out with comma as a decimal separator in my environment I must still use point in the queries. I do not know it is always like that. This works also with SQL*Plus:
SQL> select nro from test_table where nro='42,071';
Now what happens with ogrinfo is funny:
ogrinfo OCI:user/pw at db:test_table  -sql "select nro from test_table where NRO=42.071"
INFO: Open of `OCI:....'
      using driver `OCI' successful.
Layer name: select nro from test_table where NRO=42.071
Geometry: Unknown (any)
Feature Count: 1
Layer SRS WKT:
(unknown)
NRO: Real (0.0)
OGRFeature(select nro from test_table where NRO=42.071):0
  NRO (Real) = 42
My old GDAL truncates the output at the comma.
I can't test with Mapserver right now. I think still that creating an issue is a right thing to do because your trouble is real. I do not know how and where it should be corrected. Perhaps it would work if Mapserver takes care of using always point as a decimal separator in queries even is Oracle is sending back commas? That seems at least to be the right thing to do with SQL*Plus that is a native Oracle product.
I do not believe that tokenizer is the component that fails. Perhaps it fails but sending commas as decimal separator would probably still yield an error.
-Jukka Rahkonen-
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150519/058022da/attachment-0001.html>
