[mapserver-users] stretching imagery in MapServer
Mark Volz MarkVolz at co.lyon.mn.us
Tue May 26 12:07:42 PDT 2015
Jukka, (and others)
Thank you for your reply.  I think I figured out how lut works.  If you don't mind please check and make sure I have this correct:
I can use ArcGIS to report the correct input and output values for a n=2.5 standard deviation by going to layers->symbology->stretch->histograms->Info window.  Once I have those values I can modify my map file to include for example:
PROCESSING "LUT_1=73:0,226:255" #changes red band input of 0-73 to 0, inputs of 226-255 to 255, inputs between 73-226 linearly interpolated.
PROCESSING "LUT_2=60:0,199:255" #changes green band input of 0-60 to 0, inputs of 199-255 to 255, inputs between 60-199 linearly interpolated.
PROCESSING "LUT_3=35:0,155:255" #changes blue band input of 0-35 to 0, inputs of 155-255 to 255, inputs between 35-155 linearly interpolated.
P.S.
Before I knew what the heck I was doing with LUT I noticed that I could identify wet areas, and tree cover quite easily with the following combinations:
PROCESSING "LUT=50:50,60:250,70:250" is a good way to identify tree cover.
PROCESSING "LUT=50:50,60:250,70:70"  is a good way to identify wet areas.
Thank You
Sincerely,
Mark Volz, GISP
From: Rahkonen Jukka (MML) [mailto:jukka.rahkonen at maanmittauslaitos.fi]
Sent: Monday, May 25, 2015 9:18 AM
To: Mark Volz; mapserver-users at lists.osgeo.org
Subject: Re: stretching imagery in MapServer
As far as I know automatic stretch by standard deviation is not supported. You can do automatic min-max stretch with PROCESSING "SCALE=AUTO". If your source data is uniform you may reach a good result with manual scale settings or with PROCESSING "LUT=  "
-Jukka Rahkonen-
Mark Volz wrote:
Hello,
I added our new Pictometry Air Photos on our mapping site at http://geomoose.lyonco.org/geomoose2/geomoose.html.  The air photos seem somewhat washed out.  In ArcGIS I was able to get a nicer looking image by stretching the air photo using standard deviations.  Can we stretch imagery in MapServer?  If not please let me know if you have a comment regarding how I can improve the image quality.
Thanks
Sincerely,
Mark Volz, GISP
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150526/d0e0b50f/attachment.html>
