[mapserver-users] getting corrupted png with WMS request to mapserv CGI on command line
Renzo Kottmann rkottman at mpi-bremen.de
Wed May 27 02:47:18 PDT 2015
Hi All,
I have installed mapserver 6.4.1 in a docker container based on debian
jessie (see dockerfile below)
If I run:
/usr/lib/cgi-bin/mapserv -nh
"QUERY_STRING=EXCEPTIONS=application/vnd.ogc.se_inimage&REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&map=/genes-mapserver/wms_test.map&SRS=EPSG:4326&BBOX=-180,-90,180,90&FORMAT=image/png&WIDTH=1080&HEIGHT=614&STYLES=&LAYERS=satellite_mod"
> /tmp/test.png
The png is corrupt and I can not open it with neither gimp nor firefox.
However, I get valid pngs using the very same map file with shp2img or
mapserv -nh
"QUERY_STRING=map=/genes-mapserver/wms_test.map&mode=map&layers=satellite_mod
Find below more details (mapserver version, exact command lines I used and
resulting debug logs, map file, and docker file)
I searched google, the mailing list archives, but nothing seems to be
similar to this problem. Therefore, any help is very much appreciated :)
ciao,
renzo
* Mapserver Version:
MapServer version 6.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML
SUPPORTS=PROJ SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE
SUPPORTS=CAIRO SUPPORTS=SVG_SYMBOLS SUPPORTS=RSVG SUPPORTS=ICONV
SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
* Command lines
Generates valid png:
"QUERY_STRING=map=/genes-mapserver/wms_test.map&mode=map&layers=satellite_mod"
> /tmp/test.png
shp2img --all_debug 2 -m /genes-mapserver/wms_test.map -o /tmp/test.png
Generates invalid corrupt png:
> /tmp/test.png
* Log file (for all three runs in that order):
[Wed May 27 08:51:44 2015].475696 CGI Request 1 on process 79
[Wed May 27 08:51:44 2015].476881 msDrawMap(): rendering using outputformat
named png (AGG/PNG).
[Wed May 27 08:51:44 2015].476916 msDrawMap(): WMS/WFS set-up and query,
0.000s
[Wed May 27 08:51:44 2015].478222 msDrawRasterLayerLow(satellite_mod):
entering.
[Wed May 27 08:51:45 2015].16608 msDrawMap(): Layer 0 (satellite_mod),
0.540s
[Wed May 27 08:51:45 2015].16665 msDrawMap(): Drawing Label Cache, 0.000s
[Wed May 27 08:51:45 2015].16677 msDrawMap() total time: 0.541s
[Wed May 27 08:51:45 2015].38545 msSaveImage(stdout) total time: 0.022s
[Wed May 27 08:51:45 2015].38838 mapserv request processing time (msLoadMap
not incl.): 0.563s
[Wed May 27 08:56:29 2015].752703 msDrawMap(): rendering using outputformat
[Wed May 27 08:56:29 2015].752820 msDrawMap(): WMS/WFS set-up and query,
0.000s
[Wed May 27 08:56:29 2015].754465 msDrawRasterLayerLow(satellite_mod):
entering.
[Wed May 27 08:56:30 2015].295590 msDrawMap(): Layer 0 (satellite_mod),
0.543s
[Wed May 27 08:56:30 2015].295664 msDrawMap(): Drawing Label Cache, 0.000s
[Wed May 27 08:56:30 2015].295684 msDrawMap() total time: 0.544s
[Wed May 27 08:56:30 2015].323794 msSaveImage(/tmp/test.png) total time:
0.028s
[Wed May 27 08:59:28 2015].995397 CGI Request 1 on process 82
[Wed May 27 08:59:28 2015].995464 msWMSLoadGetMapParams(): enabling
non-square pixels.
[Wed May 27 08:59:28 2015].996733 msDrawMap(): kicking into non-square
pixel preserving mode.
[Wed May 27 08:59:28 2015].997595 msDrawMap(): rendering using outputformat
[Wed May 27 08:59:28 2015].997614 msDrawMap(): WMS/WFS set-up and query,
0.000s
[Wed May 27 08:59:28 2015].998950 msDrawRasterLayerLow(satellite_mod):
entering.
[Wed May 27 08:59:29 2015].651061 msDrawMap(): Layer 0 (satellite_mod),
0.653s
[Wed May 27 08:59:29 2015].651143 msDrawMap(): Drawing Label Cache, 0.000s
[Wed May 27 08:59:29 2015].651167 msDrawMap() total time: 0.656s
[Wed May 27 08:59:29 2015].681373 msSaveImage(stdout) total time: 0.030s
[Wed May 27 08:59:29 2015].681769 mapserv request processing time
(msLoadMap not incl.): 0.686s
* map file
MAP
NAME "wms_test"
STATUS ON
EXTENT -180 -90 180 90
IMAGECOLOR 210 210 210
IMAGETYPE png
SIZE 1080 614
UNITS dd
CONFIG "MS_ERRORFILE" "/tmp/wms_test_error.txt"
DEBUG 2
PROJECTION
#this is WGS84
"init=epsg:4326"
END
SYMBOLSET "etc/symbols.sym"
FONTSET "etc/fonts/fonts.txt"
WEB
IMAGEPATH /tmp/
IMAGEURL "/tmp/"
ERROR "/error.html"
EMPTY "/no_result.html"
METADATA
### Enable WFS support
"wms_title"           "wms test"
"wms_onlineresource"  "http://localhost/wms?"
"wms_srs"             "EPSG:4326"
"wms_enable_request"  "GetCapabilities GetMap GetFeatureInfo
GetLegendGraphic"
"ows_enable_request"  "GetCapabilities GetMap GetFeatureInfo
GetLegendGraphic"
"ows_extent" "-180 -90 180 90"
"wfs_title"           "wfs test"
#necessary for the WMS GetFeatureInfo request
"WMS_FEATURE_INFO_MIME_TYPE" "text/html"
END
END
LEGEND
STATUS on
KEYSIZE 10 10
LABEL
SIZE 9
COLOR 0 0 0
TYPE truetype
ENCODING UTF-8
FONT sans
FORCE false
PARTIALS true
POSITION AUTO
END
TEMPLATE "template/legend.html" # HTML template file
END
LAYER
NAME satellite_mod
METADATA
"wms_title"     "World Map Lite"
"unit"          "false"
END #end of wms metadata
DATA data/satelliteMod.png
TYPE RASTER
STATUS ON
END
#map end
END
* Dockerfile
FROM debian:jessie
ENV GMS_DIR=/genes-mapserver
ENV LANG C.UTF-8
# Update and upgrade system
RUN apt-get -qq update --fix-missing && \
apt-get install -y cgi-mapserver mapserver-bin
RUN mkdir ${GMS_DIR}
VOLUME ${GMS_DIR}
ENTRYPOINT ["/usr/lib/cgi-bin/mapserv"]
The actual tests are done within the container by:
sudo docker run -v ~/src/genes-mapserver/:/genes-mapserver --rm
--entrypoint=/bin/bash -ti renzok/mapserver-cgi
thanks for reading :)
