[mapserver-users] How set the extent programmmatically using python mapscript
Andrea Peri
aperi2007 at gmail.com
Mon Nov 16 03:43:49 PST 2015
Hi Emanuele,
thx for response.
I try the setExtent , but unfortunatelly it seem don not exist.
Try-ing
clone_map_getlayer_li.setExtent(extent)
I have this error:
File "/usr/lib/python2.7/dist-packages/mapscript.py", line 1688, in setExtent
def setExtent(self, *args): return
_mapscript.layerObj_setExtent(self, *args)
TypeError: in method 'layerObj_setExtent', argument 2 of type 'double'
A.
2015-11-16 10:38 GMT+01:00 Emanuele Di Giacomo <edigiacomo at arpa.emr.it>:
> Hi Andrea,
> you could try using the setExtent/getExtent methods:
> clone_map_getlayer_li.setExtent(extent1.minx, extent1.miny,
> extent1.maxx, extent1.maxy)
> print("The result of add is this: %s\n" %
> (str(clone_map_getlayer_li.getExtent())))
> On 16 November 2015 at 08:51, Andrea Peri <aperi2007 at gmail.com> wrote:
>> Hi ,
>> I try unsuccesfully to programmatically set the extent of a layer
>> using mapscript python.
>> I use this code to set the extent variable:
>> #... "extent1" is a variable storing the extent I like to set.
>> print("Add this extent to the layer: %s\n" % (str(extent1)))
>> clone_map_getlayer_li.extent = extent1
>> (str(clone_map_getlayer_li.extent)))
>> But
>> The result from printf show that the extent is not update.
>> >Add this extent to the layer: { 'minx': 424785 , 'miny': 4662585 ,
>> > 'maxx': 696015 , 'maxy': 5057415 }
>> >The result of add is this: { 'minx': -1 , 'miny': -1 , 'maxx': -1 ,
>> > 'maxy': -1 }
>> What I'm wrong ?
>> Many thx for any help.
>> A.
>> Andrea Peri
>> qwerty àèìòù
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Andrea Peri
qwerty àèìòù
