[mapserver-users] Mapcache - how to deal with changes to mapcache.xml?
thomas bonfort
thomas.bonfort at gmail.com
Tue Oct 13 00:10:59 PDT 2015
if it's a change that does not incur backwards compatibility (e.g.
adding a tileset, changing the cache backend for a tileset,
enabling/disabling a server, ...) you can just issue a graceful
restart on the webserver. In your case (change of resolution), the
path you suggested is the correct one. Note that if you just need to
invalidate the cache because the stored tiles are outdated, you can do
that while the server itself is running (rm -rf on dir, or delete from
tiles in sqlite)
thomas
On 12 October 2015 at 22:48, Robert Sanson
<Robert.Sanson at asurequality.com> wrote:
> What is the recommended approach to dealing with stored tiles when changes to mapcache.xml are made, such as a change in the set of resolutions in a grid? Should we disable the Web server, delete all the existing tiles then restart the server?
> Many thanks,
> Robert Sanson
> mapserver-users at lists.osgeo.org
