[mapserver-users] Shapefile spatial index challenge
Fawcett, David (MNIT)
David.Fawcett at state.mn.us
Fri Oct 23 09:20:14 PDT 2015
I have seen examples where for the purpose of overlay operations, someone chops up their large polys into smaller ones, each with an attribute that contains the id for the large poly. I don’t know if that would fit your use case.
David.
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Ben Madin
Sent: Friday, October 23, 2015 1:23 AM
To: Lydon Chandra
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Shapefile spatial index challenge
G’day Lydon,
I feel your pain, but there is little benefit to creating more quadrants. The idea (as I understand it - could be wrong) is to be able to use a (fast) bounding box to find the polygons to test, rather than having to test against every polygon using more complex algorithms.
I suppose you could consider that if you want to find out if a point is in one or more of your polygons, the benefit of having more index squares. You only have 8 polygons (I presume) so this should limit you in most cases to only having to compare your ‘point’ with only a couple of polygons using the more complex algorithms.
hth
cheers
Ben
On 2015-10-08, at 21:31 , Lydon Chandra <lydon_chandra at technologyonecorp.com<mailto:lydon_chandra at technologyonecorp.com>> wrote:
Hi List,
How can we generate more quadrants for the spatial index for the Australia polygon below ?
Using MapServer shptree, even forcing it to go to 50 level deep, the spatial index does not have more quadrants.
More data and details at:
http://www.evernote.com/l/AhrYASBGtqVOkJn0BLqZkceADvOsA_UBfvY/
<image.png>
Kind Regards,
Don
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-users
Ben Madin
t : +61 8 6102 5535
m : +61 448 887 220
e : ben at ausvet.com.au<mailto:ben at ausvet.com.au>
AusVet Animal Health Services
18/27 Market Street, Fremantle
Western Australia
AusVet's website: http://www.ausvet.com.au Find our office: http://w3w.co/leader.code.frozen
This transmission is for the intended addressee only and is confidential information. If you have received this transmission in error, please delete it and notify the sender. The contents of this email are the opinion of the writer only and are not endorsed by AusVet Animal Health Services unless expressly stated otherwise. Although AusVet uses virus scanning software we do not accept liability for viruses or similar in any attachments. Thanks for reading. The average disclaimer at the bottom of an email is probably never read but contributes substantially to increasing the size of packet being sent through the internet and ultimately congestion.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20151023/9e1f4af7/attachment-0001.html>
