[mapserver-users] Σχετ: Encoding problem
Stefanos Anastasiou
emperor_stef at yahoo.gr
Tue Oct 27 14:32:33 PDT 2015
Yes, glyphs are there. I also tried two different glyphs in .ttf but still not working.I can't imagine what else could be wrong
Thank you..!!
Στις 10:10 μ.μ. Δευτέρα, 26 Οκτωβρίου 2015, ο/η thomas bonfort <thomas.bonfort at gmail.com> έγραψε:
The cpg file is not read/used by mapserver.
In your case, and as Stephen pointed out, you should make sure that
the font you are using with mapserver contains the glyphs for your
greek glyphs.
thomas
On 26 October 2015 at 20:37, Stefanos Anastasiou <emperor_stef at yahoo.gr> wrote:
> Well, apparently there's a problem with greek letters. I created a
> shapefile from scratch and saved it with UTF-8 encoding. A ".cpg" file is
> created along the shapefile as well that has only the "UTF-8" statement. I
> entered greek letters in the shapefile's field and used
> ENCODING UTF-8
> in the layer level. Also dbfdump gives me UTF-8 Unicode text.
> Still getting weird symbols. The only readable letter is "π"
> Thank you.
> -Stefanos
> Στις 9:11 μ.μ. Δευτέρα, 26 Οκτωβρίου 2015, ο/η thomas bonfort
>> RFC suggests all characters should iconv'd to
>> UTF-8. Am I right?
> If you're creating the datasource from scratch and have the choice,
> then yes, use UTF8. If you have an exisiting datasource you cannot
> modify, just set the LAYER->ENCODING to ISO-8859 (well, the one that
> is is supported by iconv) and the transormation to utf8 will be done
> automatically and internally by mapserver.
> thomas
>> -Stefanos
>> Στις 8:25 μ.μ. Δευτέρα, 26 Οκτωβρίου 2015, ο/η thomas bonfort
>> Stefanos,
>> First off, you *need* to know the encoding that's actually used by
>> each datasource, there's no way of guessing that reliably
>> programmatically. And since MapServer 7, the ENCODING keyword has been
>> moved to the LAYER level:
>> http://mapserver.org/development/rfc/ms-rfc-103.html
>> If you have the possibility, and/or in the future, always use UTF8
>> inside your datasources.
>> regards,
>> thomas
>> On 26 October 2015 at 19:16, Stefanos Anastasiou <emperor_stef at yahoo.gr>
>> wrote:
>>> Hello everybody.
>>> I'm having a small issue with truetype and encoding in greek. Instead of
>>> normal letters I'm getting weird symbols or even shapes.
>>> iconv -l | grep {GREEK | ISO-8859-7 | WINDOWS-1253} are all
>>> present in the system.
>>> My Mapserver version:
>>> MapServer version 7.0.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ
>>> SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=ICONV SUPPORTS=XMP
>>> SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>>> SUPPORTS=WFS_SERVER
>>> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
>>> SUPPORTS=FASTCGI
>>> SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL
>>> INPUT=SHAPEFILE
>>> My LABEL object in my code is the following:
>>> LABEL
>>> TYPE truetype
>>> FONT arial
>>> SIZE 6
>>> PARTIALS TRUE
>>> ENCODING GREEK
>>> END
>>> I also tried ENCODING ISO-8859-7 and WINDOWS-1253. But getting symbols
>>> instead of letters. The closest to human readable is with encoding
>>> UTF-8...
>>> but still.
>>> I'm probably missing something here.What is the problem ?
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20151027/fafe384e/attachment.html>
