[mapserver-users] WFS axis order in Mapserver 7.0
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Fri Oct 30 09:10:41 PDT 2015
I am testing with the latest MS4W:
MapServer version 7.0.0 (MS4W 3.1.0)
I put test data and mapfile to http://latuviitta.org/downloads/MS_axis_test.zip
Map file may have some dirt from the original one that I simplified but I did test that it shows the issue for me with request:
http://localhost:8060/cgi-bin/mapserv.exe?map=c:/ms4w/apps/axis_test.map&service=WFS&version=2.0.0&request=getfeature&typename=states_shp
Part of the response:
<gml:posList srsDimension="2">-88.071564 37.510990 -88.087883 37.476273 -88.311707 37.442852
Same lon-lat order comes with WFS 1.1.0 and of course with WFS 1.0.0.
If it works for you then perhaps the issue is in MS4W.
-Jukka Rahkonen-
Even Rouault wrote:
Le vendredi 30 octobre 2015 16:15:29, Rahkonen Jukka (MML) a écrit :
> Hi,
> I am getting EPSG:4326 data with wrong axis order from Mapserver 7.0
> and WFS 1.1.0 and 2.0.0 with my demo data. However, I believe that
> there are automatic tests which must be passed before new Mapserver
> releases are published. Where could I find data, mapfiles, and tests
> so I could compare them with my own tests?
https://github.com/mapserver/msautotest/tree/master/wxs
For example
https://github.com/mapserver/msautotest/blob/master/wxs/wfs_200.map
has
# srsName
# Next 3 requests should be equivalent in result # RUN_PARMS: wfs_200_getfeature_srsname.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WFS&VERSION=2.0.0&REQUEST=GetFeature&TYPENAMES=province&SRSNAME=EPSG:4269" > [RESULT_DEVERSION] # RUN_PARMS: wfs_200_getfeature_urn_srsname.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WFS&VERSION=2.0.0&REQUEST=GetFeature&TYPENAMES=province&SRSNAME=urn:ogc:def:crs:EPSG::4269" > [RESULT_DEVERSION] # RUN_PARMS: wfs_200_post_getfeature_srsname.xml [MAPSERV] [POST]<?xml version="1.0" ?><GetFeature service="WFS" version="2.0.0" xmlns="http://www.opengis.net/wfs/2.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/wfs/2.0 http://schemas.opengis.net/wfs/2.0/wfs.xsd"><Query srsName="EPSG:4269"
typeNames="province"></Query></GetFeature>[/POST] > [RESULT_DEVERSION] #
And if you look at :
https://github.com/mapserver/msautotest/blob/master/wxs/expected/wfs_200_getfeature_srsname.xml
the axis order seems ok (somewhere in Canada I believe)
This is with EPSG:4269 but should work similarly for EPSG:4326
> -Jukka Rahkonen-
Spatialys - Geospatial professional services http://www.spatialys.com
