[mapserver-users] PHP MapScript - Remove Layer labelitem/classitem
Worth Lutz wal3 at mindspring.com
Tue Sep 1 04:01:55 PDT 2015
Have you tried
    unset($layer->labelitem);
*Worth Lutz*
On 9/1/2015 6:08 AM, Geo-6 wrote:
> Hi everyone,
> Probably a stupid question but I can't figure it out :
> I open a Layer through " $map->getLayer() " and I want to remove "
> labelitem " and " classitem" parameters.
> I tried to set these parameters to NULL " $layer->labelitem = NULL; "
> or " $layer->set('labelitem', NULL); " and to empty "
> $layer->labelitem = ''; " or " $layer->set('labelitem', ''); " but it
> doesn't remove the " LABELITEM " in the " LAYER " in the MapFile when
> I save the MapFile " $map->save() ".
> I found that setting an int/double parameter to -1 value removes it
> (like " maxscaledenom " or " minscaledenom ").
> How can I remove " labelitem " / " classitem " parameters ?
> Thanks a lot for your help !
> MapFile before MapScript :
> LAYER
> NAME "test" CLASSITEM "myclasscolumn" LABELITEM "mylabelcolumn" ...
> END # LAYER
> MapFile after MapScript " $layer->set('labelitem', NULL); " and "
> $layer->set('classitem', NULL); " :
> LAYER
> NAME "test" CLASSITEM "" LABELITEM "" ... END # LAYER
> Jonathan Beliën
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150901/00cc6243/attachment.html>
