[mapserver-users] Mapserver 7.0 and NODATA setting
Andrea Peri aperi2007 at gmail.com
Sun Sep 6 03:32:12 PDT 2015
I have no success to find any info on the NODATA question in the
floating point raster.
Is this kind of raster suitable for use on mapserver ?
Thx.
2015-08-18 10:27 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
> HI,
> The question of NODATA processing command is not completelly clear afaik.
> Infact I found a patch from warmerdam:
> https://trac.osgeo.org/mapserver/ticket/2404
> Where it speak explicitly of a PROCESSING "NODATA" setting.
>>I would note that OFFSITE is still supported, and the usual PROCESSING "NODATA=OFF" >mechanism can be used to disable using GDAL level nodata.
> A.
> 2015-08-18 9:28 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>> Hi,
>> I have a clearly response from the log.
>> The nodata is unsupported for this kind of rasters.
>>> LoadGDALImage(rt_sat.LC8191.rt.attuale): NODATA value -9999 in GDAL
>>>file or PROCESSING directive largely ignored.  Not yet fully supported for
>>>unclassified scaled data.  The NODATA value is excluded from auto-scaling
>>>min/max computation, but will not be transparent.
>> So I must found another solution for my rasters.
>> Regards.
>> 2015-08-18 9:08 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>>> So my question is a little different.
>>> Seem that mapserver was not able to automatically understand the
>>> NODATA values of floating point rasters.
>>> In my usecase: the NODATA value is -9999.0
>>> I produce the catalog using gdaltindex, and apply the result to mapserver 7.
>>> The result is this:
>>> http://tinyurl.com/ndsdyr8
>>> The only partially solution I found was to set
>>> OFFSITE 0 0 0
>>> but it is acceptable for my usecase because the black color is a color
>>> really available inside the rasters and it is not usable as a
>>> transparent color.
>>> Is this an issue for mapserver 7 ?
>>> Thx,
>>> A.
>>> 2015-08-17 16:11 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>>>> Hi Jukka.
>>>> Perhaps you have right !
>>>> The NODATA setting is an ancient setting that I reuse always in my
>>>> mapfiles but only now I notice that the mapserver document don't
>>>> report him.
>>>> So more probably it is a false setting.
>>>> But , if the nodata setting dont exist, how say to the mapserver to
>>>> filter the nodata of a floating raster  ?
>>>> Thx.
>>>>> Andrea Peri
>>>>> qwerty àèìòù
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> mapserver-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>>> Andrea Peri
>>>> qwerty àèìòù
>>> Andrea Peri
>>> qwerty àèìòù
>> Andrea Peri
>> qwerty àèìòù
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
