[mapserver-users] R: URL redirection under Apache2-Difference WMS and WFS server
Pasquale Regina pasquale.regina at enea.it
Mon Sep 7 00:12:18 PDT 2015
if I did not add to rewriterule  &service=wms&request=getcapabilities ... not working. The problem is on wfs that reads the wfs request GetCapabilities but when I ask for qgis (add wfs layer) to add the layer (getfeature) this passes 2 times the request, getcapabilities (due to rewrite) and getfeature and generating error.
I would avoid using SERVICE in rewrite statement but no it does not work.
Pasquale.
-----Messaggio originale-----
Da: thomas bonfort [mailto:thomas.bonfort at gmail.com]
Inviato: venerdì 4 settembre 2015 19:00
A: Pasquale Regina
Cc: MapserverList OSGEO
Oggetto: Re: [mapserver-users] URL redirection under Apache2-Difference WMS and WFS server
I'd avoid using the SERVICE= rewrites as the handling of capital letters may prove to be problematic. You should also not be adding the REQUEST= and other parts in your rewrite rule.
Basically, just:
<Directory “…/public_html”>
RewriteEngine on
RewriteRule mywms(.*)?(.*)$
/cgi-bin/mapserv?map=/var/www/biss.org/public_html/pmapper/config/default/pmapper_demo_wms$1.map&$2
RewriteRule mywfs(.*)?(.*)$
/cgi-bin/mapserv?map=/var/www/biss.org/public_html/pmapper/config/default/pmapper_demo_wfs$1.map&$2
</Directory>
thomas
On 4 September 2015 at 16:54, Pasquale Regina <pasquale.regina at enea.it> wrote:
> Greetings to everyone on the user list.
> Sorry for my english.
> I have a problem to submit because I cannot frame it properly: I do
> not expect that you will solve it but you can provide guidance on how
> to deal with it and I move on.
> According with mapserver wms server howto at
> http://mapserver.org/ogc/wms_server.html, in section “Changing the
> Online Resource URL” I follow the indication “Apache environment
> variables – MS_MAPFILE”. So I create a link in http cgi-bin folder
> named mywms which points to /usr/lib/cgi-bin/mapserv, the application/executable file.
> My http.conf file contain instruction:
> Alias /mywms /usr/lib/cgi-bin/mapserver
> <Location /mywms>
> SetHandler cgi-script
> Options ExecCGI
> SetEnv MS_MAPFILE
> /var/www/biss.org/public_html/pmapper/config/default/pmapper_demo_wms.
> map
> </Location>
> And the application correctly works and in a wms gis client I can
> connect to wms server with follow link www.biss.org/mywms.
> This is configuration to access to a single default mapfile
> (pmapper_demo_wms.map).
> In a similar way for a wfs server with pmapper_demo_wfs.map (mywfs
> link in cgi-bin folder, …)
> My project manager wants to change the settings of project by create
> individual mapfile (not only one, the default) for each registered
> user and so I need  to access the individual mapfiles inserting
> different links: in other words in a wms gis client I put the link
> www.biss.org/mywms_123_45 to point to the file
> pmapper_demo_wms_123_45.map (123_45 represents a registered user id,
> one of actually 75 registered users!! So I don’t create
> 75 and on link…). The map files are created automatically by the
> database on user’s registration for both wms e wfs mapfile.
> So I changed in http.conf toward rewrite rule solution (and remove
> references to Alias /mywxx and <Location /mywxx> for both mywms and
> mywfs)
> in
> RewriteEngine on
> RewriteRule myw?(.)s(.*)$
> ult/pmapper_demo_w$1s$2.map&SERVICE=W$1S&REQUEST=GetCapabilities&
> </Directory>
> So when I put http://www.biss.org/mywms_123_45 in QGIS --> add WMS
> layer it works because point to
> pmapper_demo_wms_123_45.map&SERVICE=WmS&REQUEST=GetCapabilities
> according to $1=m and $2=_123_45 variables.
> The problem arises with wfs request in QGIS à add WFS vector. Putting
> http://www.biss.org/mywfs_123_45 QGIS (and other wfs client similar)
> sends the response in attached “Il server WFS non supporta la versione
> WFS 1.0.0 oppure l’ URL è errato” (Italian language!!) while putting
> http://www.biss.org/cgi-bin/mapserv?map=/var/www/biss.org/public_html/
> pmapper/config/default/pmapper_demo_wfs_123_45.map
> it works correctly (which demonstrate that mapfile is ok! and in the
> layer properties I read correctly …&SERVICE=WFS&VERSION=1.0.0&REQ….)
> what it is due to the difference in behavior for mapserver when
> rewrite the url? Is it a feature of wfs server?
> Can you direct me?
> Thanks in advance. Pasquale.
> PS. Apache2 version 2.4.7 on Ubuntu 14.04 MapServer 6.4.1
> mapserver-users at lists.osgeo.org
