[mapserver-users] CSV from Mapscript results
Matej Mailing mailing at tam.si
Tue Sep 8 17:03:44 PDT 2015
Thanks, Steve.
It looks I will choose the 2nd option as well. What I don't like with
this "direct" approach though is not using already existing Mapfile
with DATA, CONNECTION and everything set - basically it creates
another point where this data needs to be set and changed for example
when changing access rights, moving data to new server etc., it
increases complexity.
As far as I have checked, there is no for example getData() method to
get the DATA variable, set in the Mapfile. (Perhaps the reason is that
since there is no set, there is no get method as well :-))
However, in this case this would be useful or perhaps I am just
thinking in the wrong direction? :-)
Thanks,
Matej
2015-09-08 18:07 GMT+02:00 Lime, Steve D (MNIT) <Steve.Lime at state.mn.us>:
> You have two options:
>   1 - use query templates to render the result as CSV
>   2 - use whatever tool your programming language gives you and just loop through the results and dump to CSV
> Personally since you're using MapScript I'd opt for 2 for a couple of reasons: you have total control that way and for larger result sets it's likely to be more performant since the whole CSV file wouldn't need to be constructed in memory like templates would.
> Steve
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Matej Mailing
> Sent: Tuesday, September 08, 2015 5:30 AM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] CSV from Mapscript results
> Hi,
> what would be the best way to create a CSV from Mapscript query results?
> Thanks,
> Matej
