[mapserver-users] OWS BoundingBox output loss of precision
Fergus McDonald mapserver at schartz.net
Wed Sep 23 07:46:35 PDT 2015
I have an extent param in a MAP file declared as
-10832766.418414999
but in the WMS GetCapabilities response the BoundingBox gives it as
-1.08328e+07
There appears to be a loss of precision in mapows.c when the value is
output using the %g formatting.
I found this old fix on trac
http://trac.osgeo.org/mapserver/ticket/1232
but that resolved this issue for WCS output only, by updating %g to
%.15g within mapwcs.c
Does this fix also need to be applied to mapows.c?
The loss of precision is causing problems with client size map
calculations when working at high resolutions.
