[mapserver-users] Shapefile features = 0 (zero integer value) are empty and ignored? [SEC=UNCLASSIFIED]
thomas bonfort thomas.bonfort at gmail.com
Fri Apr 1 02:25:47 PDT 2016
What expression syntax are you using in your mapfile to select/filter these
features?
Thomas
On 1 April 2016 at 02:40, Inna Nogeste <I.Nogeste at bom.gov.au> wrote:
> I'm using MapServer 6.4 and have a shapefile where features have an
> attribute = 0 (zero integer value). I want to display these features = 0
> but they seem to be regarded as null/empty features in MapServer so are
> ignored and won’t display on the map.
> Other integer values in the same field can be displayed on the map,
> including the value of -1, but not 0.
> I can select these records = 0 in ArcGIS and QGIS 2.8.2
> Can anyone tell me how, or if, shapefile features with attribute = 0
> integer value can be used in a MapServer expression, or how to enter values
> = 0 in to a shapefile for MapServer Expressions?
> Regards,
> Inna Nogeste | Spatial Information Specialist
> Geospatial Data and Services
> Information Systems and Services Division
> Bureau of Meteorology
> www.bom.gov.au
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160401/194c145b/attachment.html>
