[mapserver-users] selecting a wms layer
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Mon Apr 4 02:23:45 PDT 2016
It never hurts to read the whole documentation ☺
There is 'ows_name' 'rt_cat' in the mapfile and the manual page says also:
Note
Note that each of the above metadata can also be referred to as ‘ows_*’ instead of ‘wms_*’. MapServer tries the ‘wms_*’ metadata first, and if not found it tries the corresponding ‘ows_*’ name. Using this reduces the amount of duplication in mapfiles that support multiple OGC interfaces since “ows_*” metadata can be used almost everywhere for common metadata items shared by multiple OGC interfaces.
-Jukka Rahkonen-
Lähettäjä: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta thomas bonfort
Lähetetty: 4. huhtikuuta 2016 12:16
Vastaanottaja: pippi
Kopio: MapserverList OSGEO
Aihe: Re: [mapserver-users] selecting a wms layer
Peter,
It never hurts to read the documentation: http://mapserver.org/ogc/wms_client.html#mapfile-configuration . Namely the part where the "wms_name" metadata key is required and what you need.
Thomas
On 4 April 2016 at 10:56, pippi <p.laranci at terrasystem.it<mailto:p.laranci at terrasystem.it>> wrote:
hello,
I can correctly visualize a wms layer with mapserver and pmapper as:
CONNECTION
'http://web.regione.toscana.it/wmsraster/com.rt.wms.RTmap/wms?map=wmscatasto'.
If I add the &layer parameter, it still works, but no selection of the
choosen layers is done (while in Qgis it is possible):
CONNECTION
'http://web.regione.toscana.it/wmsraster/com.rt.wms.RTmap/wms?map=wmscatasto&layer=rt_cat.idcatpart.rt,rt_cat.idcatacque.rt,rt_cat.idcatstrade.rt,rt_cat.idcatfabbr.rt,rt_cat.idcatbdfog.rt'
Can someone give me any clue please? how can I choose just the layers that I
need?
this is the complete code of the layer:
LAYER
    NAME 'Catasto-Toscana'
    GROUP "Catasto"
    TYPE RASTER
    DUMP true
    TEMPLATE "map.html"
    CONNECTIONTYPE WMS
    CONNECTION
    MAXSCALEDENOM 10000
    METADATA
       "DESCRIPTION" "Catastale terreni (test)"
      'ows_name' 'rt_cat'
      'wms_server_version' '1.1.1'   # con 1.3.0 come da metadati si blocca
      'ows_srs' 'EPSG:32632'
      'wms_format' 'image/png'
      'wms_style' 'default'
    END
    STATUS OFF
    TRANSPARENCY 100
    PROJECTION
                "init=epsg:32632"
    END
  END
Peter
View this message in context: http://osgeo-org.1560.x6.nabble.com/selecting-a-wms-layer-tp5259459.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160404/c097cf3d/attachment.html>
