[mapserver-users] Oracle SYSDATE in EXPRESSION
Basques, Bob (CI-StPaul)
bob.basques at ci.stpaul.mn.us
Mon Apr 4 07:19:04 PDT 2016
I went the view route for the time being, to get one of the class types (layer) up and running. I was basing my questions on the fact that I’ve successfully passed in all sorts of SQL into the Postgres connector with MapServer, but the Oracle connector seems to be some limited in what it can send in successfully, or there are some escaping sequences I don’t know about.
I tried a few things for making it work the fly, but nothing was working.
I ended up creating a view as Dan Little suggested. I could probably get by with doing the FOLDERTYPE filtering (Last line below) in the MapFile as a quick way of making all the Permit class types work.
create view
PW_SK_Permits
as
select
P.DEPARTMENT,
P.INDATE,
CASE WHEN
P.INDATE < SYSDATE - 365 * 5
THEN
'older'
ELSE
'newer'
END as age,
P.FOLDERTYPE,
P.FOLDERDESC,
P.FOLDERRSN,
P.FOLDERID,
A.PIN,
A.GEOMETRY,
A.OGR_FID
from
STAMP.PW_Permits P, ADDRESS_ACTIVE_OGR_VIEW A
where
P.PIN is not NULL
and
P.PIN = A.PIN
and
P.FOLDERTYPE IN ('SK') -- PW Sidewalks
I needed to get this SideWalk Permit layer up and running either way. Something similar to the inner select above works just fine via MapServer/Postgres though.
Now how to figure things out for the other 119 permit types. :c)
bobb
On Apr 4, 2016, at 5:28 AM, Martin Icking <martin.icking at bentley.com<mailto:martin.icking at bentley.com>> wrote:
Or you could create a calculated column in the data statement, call it e.g.
"AGE" being the result of the difference of your original date column and
the oracle sysdate.
Then you can easily use that "AGE" column to do your styling.
HTH
Martin
View this message in context: http://osgeo-org.1560.x6.nabble.com/Oracle-SYSDATE-in-EXPRESSION-tp5258709p5259480.html
Sent from the Mapserver - User mailing list archive at Nabble.com<http://nabble.com>.
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160404/4756ecd6/attachment.html>
