[mapserver-users] Shapefile features = 0 (zero integer value) are empty and ignored? [SEC=UNCLASSIFIED]
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Apr 4 09:05:28 PDT 2016
On 2016-04-04 12:33 AM, Inna Nogeste wrote:
> Hi Thomas,
> After many attempts using the same expression syntax it finally worked.
> Is there any reason as to why the following expression syntax didn’t
> work the first time?
You could be hitting a weird issue in your DBF file, where your
attributes are stored. As I mentioned earlier to you, you could test
further by using the ogrinfo commandline tool to return the column
types, and also step through the values, such as:
ogrinfo myfile.shp myfile |more
That should allow you to step through each value, and note how your zero
integer values appear to the GDAL/OGR library.
You can also pass your expression directly to the ogrinfo tool, and
check the response for the correct "feature count" value, such as:
ogrinfo -where "INT_TEST = 0" myfile.shp myfile -summary
Then you could also change your mapfile layer such as:
LAYER
CONNECTIONTYPE OGR
CONNECTION "myfile.shp"
CLASSITEM "INT_TEST"
CLASS
EXPRESSION "0"
END #class
END #layer
You can also do some more testing, by creating a new integer column in
you DBF, setting a few zero values in it, and then re-testing in
MapServer through the shp2img command. Likely you will find an odd
problem with the old integer column.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
