[mapserver-users] tinyows does not show vector layer
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed Apr 13 04:53:35 PDT 2016
To followup on the other comments and Jukka's recommendation: you can
set specific parameters for your FastCGI use - in the case of MS4W, we
use the Apache module named 'mod_fcgi', and you can set its parameters
in Apache's 'httpd.conf' file: for a list of these parameters see
http://httpd.apache.org/mod_fcgid/mod/mod_fcgid.html
An example setting to limit the maximum time a process is running/alive
to 10 seconds:
   FcgidProcessLifeTime 10
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2016-04-13 4:12 AM, Rahkonen Jukka (MML) wrote:
> Hi ,
> You could have mentioned that you have asked the same question in
> gis.stackexchange
> http://gis.stackexchange.com/questions/189102/tinyows-does-not-show-vector-layer
> . Reading the comments may help Mapserver users to give you a better
> answer and faster.
> -Jukka Rahkonen-
> vineet singh wrote:
> Hi Everyone,
> I'm using tinyows server configured with config.xml file. I'm adding
> vector layer to config file and for the first time it does not show
> newly added layer, but once i have restarted the tinyows server than it
> will show the layer.
> So i have to restart tinyows after adding new layer. Anyone know how can
> I fix this so that it will work without restarting.
> I'm runing TinyOWS as fast-cgi.
> Here is config.xml :
> <tinyows log="/home/vineet/Project/mygis/data/logs/wfs.log"
> log_level="15" online_resource="http://192.168.0.35:19090/maps"
> schema_dir="/home/vineet/Project/mygis/data/schema">
> <pg dbname="mygis" host="localhost" password="abcd" port="19095"
> user="mygis"/>
> <metadata name="MyGis Server" title="MyGis Server - WFS-T Service"/>
> <contact email="contact at xxxx.com <mailto:contact at xxxx.com>" name="MyGis
> Server" site="http://www.xxxxx.com/"/>
> <layer
> retrievable="1"  writable="1" ns_prefix="tows" ns_uri="http://www.vizexperts.com/"
>   name="world_boundaries"
>   title="World Borders" />
>   </tinyows>
> Thanks,
> Vineet Singh
