[mapserver-users] WFS layer - XML/JSON safe chars
Richard Watson trailway at gmail.com
Fri Apr 15 07:41:28 PDT 2016
I am using Map Server 6.4.1.  I have a map project file which has the
following title:
  WEB
    METADATA
      [ text omitted]
      "wms_title" "(*#(@#*$_)@#&\\\///"
    END # METADATA
  END # WEB
When a GetCapabilties is done on the project then this is the source XML
which is returned:
<Service>
<Name>WMS</Name>
<Title>(*#(@#*$_)@#&\\///</Title>
It seems to be escaping as required.
On Fri, Apr 15, 2016 at 9:21 AM, Rahkonen Jukka (MML) <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi,
> I was thinking that the output of GetCapabilities is XML and & must be
> escaped in XML. So if I write & into the abstract and Mapserver works
> correctly it should write my test abstract “test ä &”  escaped perhaps as
> test ä &
> That is the output from the online tool at
> http://www.freeformatter.com/xml-escape.html#ad-output
> So my conclusion was that because Mapserver does not do it right here it
> won’t do it right elsewhere.
> But now I made another test by editing the Geoserver test file
> “states.shp” in Spatialite as
> UPDATE states set STATE_NAME=’Colo&rado’ WHERE STATE_NAME=’Colorado’;
> Output of GetFeature from WFS 1.1.0 from Mapserver 7.0.0  includes
>      <ms:STATE_NAME>Colo&rado</ms:STATE_NAME>
> So my current conclusion is that my Mapserver does not escape “&”
> correctly when it is used inside a mapfile and when I do GetCapabilities
> request. However, when data come from Spatialite database and they are
> consumed by GetFeature then escaping happens correctly.
> We are still comparing different things because you have PostGIS and I
> have Spatialite.
> -Jukka Rahkonen-
> Ian Walberg wrote:
> Jukka,
> I am not sure I understand the test you did.
> The data we are referring to is from the database field for the individual
> features name.
> Regards
> Ian
> *From:* Rahkonen Jukka (MML) [mailto:jukka.rahkonen at maanmittauslaitos.fi
> <jukka.rahkonen at maanmittauslaitos.fi>]
> *Sent:* Thursday, April 14, 2016 10:19 PM
> *To:* Ian Walberg <ian.walberg at airborne.aero>; MapserverList OSGEO <
> mapserver-users at lists.osgeo.org>
> *Subject:* Re: WFS layer - XML/JSON safe chars
> Hi Ian,
> Thanks for the clarification.
> I made a simple test by adding an abstract into layer metadata. This shows
> “test ä” as an abstract
> "wfs_abstract" "test ä”
> This one shows an empty abstract
> "wfs_abstract" "test ä &"
> So it looks like Mapserver doesn’t know to convert “&” into “&” for
> XML.
> -Jukka Rahkonen-
> Ian Walberg wrote:
> Jukka,
> Our question was for the data/text read from the database and then
> published as XML by the WFS service.
> So a pub with the name ‘Dog & bone’ created illegal xml as the & is not
> converted to &
> Regards
> Ian
> *Sent:* Thursday, April 14, 2016 3:10 PM
> Hi,
> You can’t have & in feature type names or attribute names in WFS because
> they are defined in the XML schema to be “QName”. The prefix and LocalPart
> are of type NCName https://en.wikipedia.org/wiki/QName and from
> http://stackoverflow.com/questions/1631396/what-is-an-xsncname-type-and-when-should-it-be-used
> The practical restrictions of NCName are that it cannot contain several
> symbol characters like :, @, $, %, &, /, +, ,, ;, whitespace characters
> or different parenthesis. Furthermore an NCName cannot begin with a number,
> dot or minus character although they can appear later in an NCName.
> -Jukka Rahkonen-
> *Lähettäjä:* mapserver-users [
> mailto:mapserver-users-bounces at lists.osgeo.org
> <mapserver-users-bounces at lists.osgeo.org>] *Puolesta *Ian Walberg
> *Lähetetty:* 14. huhtikuuta 2016 19:23
> *Vastaanottaja:* MapserverList OSGEO
> *Aihe:* [mapserver-users] WFS layer - XML/JSON safe chars
> Folks,
> Can mapserver produce XML or JSON safe characters for WFS served data or
> do we need to ensure the source data has the escaped values.
> We got tripped up today as there were some ‘&’ in our names which we had
> not considered.
> Thanks
> Ian
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160415/b102d927/attachment.html>
