[mapserver-users] RE OGR csv - no field names
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Apr 25 14:51:33 PDT 2016
Actually I am able to use a .vrt with no field names:
<OGRVRTDataSource>
<OGRVRTLayer name="occurrence">
<SrcDataSource relativeToVRT="1">CSV:occurrence.txt</SrcDataSource>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS>WGS84</LayerSRS>
<GeometryField encoding="PointFromColumns" x="field_37"
y="field_38"/>
</OGRVRTLayer>
</OGRVRTDataSource>
and ogrinfo does find the geometry with that vrt:
INFO: Open of `occurrence.vrt'
using driver `OGR_VRT' successful.
Layer name: occurrence
Geometry: Point
Feature Count: 75
Extent: (45.726390, -64.603440) - (45.726860, -64.575430)
Layer SRS WKT:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563
As for using those fields in a CLASSITEM etc in the mapfile layer, I am
unable.
I am testing with MS4W 3.1.3 (MapServer 7.0.1).
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2016-04-25 5:32 PM, Ian Walberg wrote:
> Thanks for the ideas.
> I think the vrt file needs the csv fields to have names unless I
> misunderstand.
> CSVT file – does this specify the column/field data type? Can the name
> be specified as well?
> Regards
> Ian
> *From:*Simon Mercier [mailto:smercier at mapgears.com]
> *Sent:* Monday, April 25, 2016 10:31 AM
> *To:* Steve.Toutant at inspq.qc.ca; Ian Walberg <ian.walberg at airborne.aero>
> *Cc:* mapserver-users at lists.osgeo.org; mapserver-users
> <mapserver-users-bounces at lists.osgeo.org>
> *Subject:* Re: [mapserver-users] RE OGR csv - no field names
> why not use a vrt file instead! http://www.gdal.org/drv_vrt.html
> <OGRVRTDataSource>
> <OGRVRTLayer name="precipitation">
> <SrcDataSource>precipitation.csv</SrcDataSource>
> <LayerSRS>EPSG:4326</LayerSRS>
> <GeometryField encoding="PointFromColumns" x="lon" y="lat"/>
> <Field name="precipitation_mm" src="prec_mm"/>
> </OGRVRTLayer>
> </OGRVRTDataSource>
> On 16-04-25 08:01 AM, Steve.Toutant at inspq.qc.ca
> <mailto:Steve.Toutant at inspq.qc.ca> wrote:
> I don't know why LABELITEM 'filed_3' would not work in your case
> You can try to specify column names by using a .csvt file
> http://www.gdal.org/drv_csv.html
> Example:
> https://anitagraser.com/2011/03/07/how-to-specify-data-types-of-csv-columns-for-use-in-qgis/
> *Ian Walberg <ian.walberg at airborne.aero>
> <mailto:ian.walberg at airborne.aero>@lists.osgeo.org*
> Envoyé par : "mapserver-users"
> <mailto:mapserver-users-bounces at lists.osgeo.org>
> 2016-04-23 22:50
> A
> "mapserver-users at lists.osgeo.org"
> <mailto:mapserver-users at lists.osgeo.org>
> <mapserver-users at lists.osgeo.org>
> cc
> Objet
> [mapserver-users] OGR csv - no field names
> Folks,
> Can a csv file with no field names as the first row be used as an
> OGR source?
> GDAL creates dummy field names, are these passed to mapserver?
> OGRFeature(USA-Hilton):652
> field_1 (String) = -74.16958
> field_2 (String) = 40.73526
> field_3 (String) = Penn Station
> What do we need in the layer to make this work?
> LABELITEM 'name' - this throws an error, 'field_3' does not seem to
> work either.
> CONNECTIONTYPE OGR
> CONNECTION 'Stations.csv'
> Thanks
> Ian
> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
> simon mercier
> mapgears
> +1.418.476.7139 p101
