[mapserver-users] OGR csv - no field names
Schepers, Benjamin
schepers at rvr-online.de
Mon Apr 25 21:58:36 PDT 2016
Hi Ian,
maybe creating a .vrt-File helps? This works as a preprocessor/transformer - the impact on performance for that kind of modification shouldn't be noticeable.
Mapserver can read those vrt-Files, so this could be a solution for you.
There is an example at the gdal-csv-driver documentation:
http://www.gdal.org/drv_csv.html
Regards
Benjamin
Benjamin Schepers
Luftbild und Geoinformationssysteme
luftbilder.geoportal.ruhr
Kronprinzenstraße 35
45128 Essen
Germany
www.metropoleruhr.de
-----Ursprüngliche Nachricht-----
Von: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag von Ian Walberg
Gesendet: Sonntag, 24. April 2016 04:50
An: mapserver-users at lists.osgeo.org
Betreff: [mapserver-users] OGR csv - no field names
Folks,
Can a csv file with no field names as the first row be used as an OGR source?
GDAL creates dummy field names, are these passed to mapserver?
OGRFeature(USA-Hilton):652
field_1 (String) = -74.16958
field_2 (String) = 40.73526
field_3 (String) = Penn Station
What do we need in the layer to make this work?
LABELITEM 'name' - this throws an error, 'field_3' does not seem to work either.
CONNECTIONTYPE OGR
CONNECTION 'Stations.csv'
Thanks
Ian
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
