[mapserver-users] RE OGR csv - no field names
Simon Mercier
smercier at mapgears.com
Tue Apr 26 08:52:44 PDT 2016
try to get it through your mapfile! base on what I read here
http://mapserver.org/input/vector/ogr.html#using-ogr-data-sources-in-the-map-file,
you'll supposed to be able to add an SQL in DATA tag for any OGR data
source, and there you should be able to select fid... I guess
LAYER
CONNECTIONTYPE OGR
CONNECTION "<datasource_name>"
DATA "select fid, field_1, field_2, field_3 from <datasource_name>"
END
On 16-04-26 11:05 AM, Ian Walberg wrote:
> Simon,
> We tried this yesterday but could not see how to include the sql statement in the vrt file so that mapserver got an fid for each record.
> Thanks
> Ian
> -----Original Message-----
> From: Simon Mercier [mailto:smercier at mapgears.com]
> Sent: Tuesday, April 26, 2016 8:01 AM
> To: Ian Walberg <ian.walberg at airborne.aero>; mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] RE OGR csv - no field names
> Ian
> Try with FID field, OGR generate this ID for you. But you should try use your own ID field for consistency between version of your data (if needed). I tested with my demo data and I can select FID even if it doesn't exist in source file.
> <OGRVRTDataSource>
> <OGRVRTLayer name="Inventory">
> <SrcDataSource>/home/smercier/data/vrt/Inventory.csv</SrcDataSource>
> <GeometryType>wkbPoint</GeometryType>
> <LayerSRS>EPSG:4326</LayerSRS>
> <GeometryField encoding="PointFromColumns" x="longitude"
> y="latitude"/>
> <Field name="site_name" src="SiteName"/>
> <Field name="site_phone" src="SitePhone"/>
> <Field name="site_type" src="SiteType"/>
> <Field name="address" src="address"/>
> <Field name="site_aed_placement" src="AEDPlacementLocation"/>
> </OGRVRTLayer>
> </OGRVRTDataSource>
> smercier at optimus: $ ogrinfo Inventory.vrt -sql "select fid from Inventory"
> INFO: Open of `Inventory.vrt'
> using driver `VRT' successful.
> Layer name: Inventory
> Geometry: Point
> Feature Count: 117
> Extent: (-80.977043, 0.000000) - (0.000000, 43.978620) Layer SRS WKT:
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563,
> AUTHORITY["EPSG","7030"]],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.0174532925199433,
> AUTHORITY["EPSG","9122"]],
> AUTHORITY["EPSG","4326"]]
> fid: Integer (0.0)
> OGRFeature(Inventory):1
> fid (Integer) = 1
> POINT (-80.2171407 43.4970847)
> OGRFeature(Inventory):2
> fid (Integer) = 2
> POINT (-80.5357573 43.8367679)
> OGRFeature(Inventory):3
> fid (Integer) = 3
> POINT (0 0)
> On 16-04-25 07:11 PM, Ian Walberg wrote:
>> Jeff,
>> Many thanks that worked great.
>> Next is there any way of getting the row ID as part of the data passed to mapserver?
>> We are planning to serve this data as a WFS layer.
>> Thanks
>> Ian
>> From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org]
>> On Behalf Of Jeff McKenna
>> Sent: Monday, April 25, 2016 3:03 PM
>> To: mapserver-users at lists.osgeo.org
>> On 2016-04-25 6:49 PM, Simon Mercier wrote:
>>> really not sure CSVT file is supported by ogr, but you can easily
>>> define field type in VRT
>>> <Field name="precipitation_mm" src="prec_mm" type="Real"/>
>>> <Field name="field_1" src="field_1" type="String" width="100"
>> Simon is right, very nice, specifying the field name to classify in the vrt works, for a csv without field names:
>> <OGRVRTDataSource>
>> <OGRVRTLayer name="occurrence">
>> <SrcDataSource relativeToVRT="1">CSV:occurrence.txt</SrcDataSource>
>> <LayerSRS>WGS84</LayerSRS>
>> <GeometryField encoding="PointFromColumns" x="field_37"
>> y="field_38"/>
>> <Field name="name" src="field_51" type="String" width="100"/>
>> </OGRVRTLayer>
>> </OGRVRTDataSource>
>> LAYER
>> NAME "occurrence"
>> TYPE POINT
>> STATUS ON
>> CONNECTIONTYPE OGR
>> CONNECTION "../occurrence.vrt"
>> CLASSITEM "name"
>> CLASS
>> NAME "Occurrences"
>> EXPRESSION "ttt"
>> STYLE
>> SYMBOL 7
>> SIZE 10
>> COLOR 0 0 0
>> END
>> END
>> END # Layer
>> -jeff
>> Jeff McKenna
>> MapServer Consulting and Training Services
>> http://www.gatewaygeomatics.com/
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> simon mercier
> mapgears
> +1.418.476.7139 p101
simon mercier
mapgears
