[mapserver-users] problem in wms service
Yves Jacolin
yves.jacolin at camptocamp.com
Tue Aug 16 00:37:46 PDT 2016
Ok, I suppose that your working test shows something in the picture?
I suggest to enable log in your mapfile and check it after running again your
not working example.
"map.extent=2588830.423584977+4061255.6481961836+54
26172.9135307195+5382087.496964029" in your request should not be useful.
Sorry no more idea here. Maybe the log will show you something weird.
Y.
On Tuesday, August 16, 2016 10:20:43 Ahmet Temiz wrote:
> thank you
> it is png file.
> $display out.png returns blank image.
> On Tue, Aug 16, 2016 at 10:10 AM, Yves Jacolin <yves.jacolin at camptocamp.com>
> wrote:
> > On Tuesday, August 16, 2016 10:07:40 Ahmet Temiz wrote:
> > > Hi,
> > > I am testing my wms, postgis layer it works with QUERY_STRING but not
> > > displays anything with curl and QGIS.
> > > ** It works
> > > mapserv -nh
> > > "QUERY_STRING=map=/var/www/ms_map/jeo.map&SERVICE=WMS&
> > VERSION=1.1.1&REQUEST=
> > > GetMap&map.extent=2588830.423584977+4061255.6481961836+
> > 5426172.9135307195+53
> > > 82087.496964029&LAYERS=jeo&STYLES=&SRS=EPSG:3857&BBOX=
> > 2588830.423584977,4061
> > > 255.6481961836,5426172.9135307195,5382087.496964029&
> > WIDTH=1160&HEIGHT=540&FO
> > > RMAT=image/png"
> > > ** it doesn't work
> > > curl --trace -i -X GET -H "Content-Type: image/png" "
> > > http://localhost/cgi-bin/mapserv?map=/var/www/ms_map/
> > jeo.map&SERVICE=WMS&VER
> > > SION=1.1.1&REQUEST=GetMap&map.extent=2588830.423584977+
> > > 26172.9135307195+5382087.496964029&LAYERS=jeo&STYLES=&
> > SRS=EPSG:3857&BBOX=258
> > > 8830.423584977,4061255.6481961836,5426172.9135307195,
> > 5382087.496964029&WIDTH
> > > =1160&HEIGHT=540&FORMAT=image/png"
> > > Can you tell me what the likely reasons are?
> > > regards
> > Hello,
> > Does out.png is a png file or a text file with an error message in it? If
> > so,
> > what is this message? If it is not a png file, is it the mapserv cgi file?
> > Y.
> > Responsable Formation et Support
> > Camptocamp France SAS
> > Savoie Technolac, BP 352
> > 73377 Le Bourget du Lac, Cedex
> > Tel (France) : +33 4 58 48 20 43 (new !)
> > Tel (Suisse) : +41 21 619 10 43
> > Mob. : +33 6 18 75 42 21
> > Fax : 04 79 70 15 81
> > Mail : yves.jacolin at camptocamp.com
> > http://www.camptocamp.com
