[mapserver-users] mapcache question
Jukka Sirviö Jukka.Sirvio at mipro.fi
Tue Aug 30 05:32:00 PDT 2016
I was not able to solve the problems on fresh CentOS 7 environment with all the latest libraries/dependencies included. on old test environment, I did upgrade/build to gdal 2.1.1 and also latest mapcache master. this environment is working as one would expect according given instructions in http://mapserver.org/mapcache/install.html.
so basically now I'm back on the already achieved square 1, with that difference, that the versions of mapcache and gdal are upgraded. ==> now I'm able to proceed with Thomas suggestion with GDAL data source and GDAL WMTS driver.
From this point of view, this post is completed, thus, more questions will come!
Thanks for patience..
-----Alkuperäinen viesti-----
Lähettäjä: thomas bonfort [mailto:thomas.bonfort at gmail.com]
Lähetetty: 30. elokuuta 2016 13:19
Vastaanottaja: Jukka Sirviö
Kopio: mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] mapcache question
The demo file in master parses correctly. Again, if you're having an issue it is either because you have made invalid (in the xml sense) modifications to it, or that your apache user doesn't have access rights to it (or to the directories above it).
thomas
On 30 August 2016 at 12:11, Jukka Sirviö <Jukka.Sirvio at mipro.fi> wrote:
> file and directory rights should be ok, mapcache.xml is the demo file included in master.
> of-course, have tried this with quite a lot of ways without success, starting to feel numb.
> Lähettäjä: mapserver-users
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Guillaume
> Sueur
> Lähetetty: 29. elokuuta 2016 16:51
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Hi,
> Actually it just says there is an error in your mapcache.xml file (or maybe apache can't even access/read it). Check the files rights, check the file itself, and you should find what the problem is.
> Best regards
> Guillaume
> Le 28/08/2016 à 19:45, Jukka Sirviö a écrit :
>> Hi,
>> Thank you all for good answers and suggestions, Thomas proposal, is more or less, ideal solution for me.
>> Mapcache master is compiled according instructions at http://mapserver.org/mapcache/install.html successfully on CentOS 7 (and MapServer master & GDAL etc), but httpd fail's to start if following line "MapCacheAlias /mapcache "/bla/blabla/mapcache.xml" is included in httpd.conf. error message is:
>> AH00526: Syntax error on line 335 of /etc/httpd/conf/httpd.conf:
>> failed to parse file /home/mapcacheconf/mapcache.xml. Is it valid XML?
>> Need some hint's how to proceed? Thank's in advance!
>> -Jukka
>> Lähetetty: 25. elokuuta 2016 15:56
>> Vastaanottaja: Travis Kirstine
>> Kopio: Lime, Steve D (MNIT); Jukka Sirviö;
>> The reprojection is done inside MapCache, i.e. as a client of the
>> original tiles. You don't need an additional WMS :)
>> thomas
>> On 25 August 2016 at 14:50, Travis Kirstine <tkirstine at firstbasesolutions.com> wrote:
>>> I believe that there still would be an issue as the reprojection from X to Y, the reprojection would need to be done on the source WMTS side.  I guess you could proxy the source WMTS using mapserver with the gdal mini driver  and reproject to create a WMS to feed mapcache?
>>> -----Original Message-----
>>> From: thomas bonfort [mailto:thomas.bonfort at gmail.com]
>>> Sent: August-25-16 3:55 AM
>>> To: Lime, Steve D (MNIT) <Steve.Lime at state.mn.us>
>>> Cc: Travis Kirstine <tkirstine at firstbasesolutions.com>; Jukka Sirviö
>>> <Jukka.Sirvio at mipro.fi>; mapserver-users at lists.osgeo.org
>>> Subject: Re: [mapserver-users] mapcache question
>>> Jukka,
>>> in master, there is also support for any GDAL dataset as a mapcache source (i.e. in addition to wms). If you use that in addition to a GDAL TMS/WMS/WMTS minidriver you'll be able to reproject/store third party tiles on the fly.
>>> thomas
>>> On 24 August 2016 at 21:58, Lime, Steve D (MNIT) <Steve.Lime at state.mn.us> wrote:
>>>> I would think reprojection of individual tiles into another set of tiles that would stitch back together without artifacts would be difficult. I thought MapCache did support native MapServer mode=map as a source which could useful if GDAL supports WMTS and you could create a corresponding MapServer layer.
>>>> From: mapserver-users
>>>> On Behalf Of Travis Kirstine
>>>> Sent: Wednesday, August 24, 2016 1:14 PM
>>>> To: Jukka Sirviö <Jukka.Sirvio at mipro.fi>;
>>>> Jukka,
>>>> According to the docs mapcache only support WMS as input.
>>>> " A source is a service mod-mapcache can query to obtain image data. This is typically a WMS server accessible by a URL. (There are currently no sources other than WMS implemented, though others may be added later if the need arises)"
>>>> If this is still true then your proposed chain will not work.
>>>> MapProxy will support a tiled source and I know TMS works  (not
>>>> sure about WMTS) and handle the reprojection
>>>> Regards
>>>> On Behalf Of Jukka Sirviö
>>>> Sent: August-24-16 10:09 AM
>>>> To: mapserver-users at lists.osgeo.org
>>>> Subject: [mapserver-users] mapcache question
>>>> Hello,
>>>> I would like to put a mapcache to be in the middle, in the following chain:
>>>> 1) original wmts service in local/national crs x   -->  2) mapcache wmts, reprojection to world-wide crs y (3857) -->  3) user interface (OpenLayers v2, Qgis), also in crs y
>>>> Mapcache was compiled, and is working a-ok with demo data. But I have trouble to configure mapcache to work as a part in the above chain. As planned, Mapcache should work as a WMTS client down towards target 1 and WMTS server up against target 3, ie. kind of a proxy with crs reprojection and basic auth. Anyway, does this make any sense at all, or is the draft totally irrational?
>>>> If the draft is reasonable, could you give some hints on how to proceed related to configuration with mapcache.xml?
>>>> -Jukka
>>>> ________________________________
>>>> Tämä sähköpostiviesti (liitteineen) saattaa sisältää luottamuksellista tietoa, joka on tarkoitettu vain vastaanottajalleen. Jos et ole oikea vastaanottaja, ilmoita viestin lähettäjälle tapahtuneesta virheestä ja tuhoa viesti välittömästi. Viestin luvaton julkaiseminen, kopioiminen, jakelu tai muu käyttö tai toimenpiteisiin ryhtyminen sen perusteella on ehdottomasti kielletty.
>>>> This message (including any attachments) may contain confidential information intended for the person or entity to which it is addressed. If you are not the intended recipient, notify the sender and delete this message immediately. Notice that disclosing, copying, distributing or any other use of the message and its information, or taking any action based on it, is strictly prohibited.
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
