[mapserver-users] Mapserver 7.0.3 and disabling default extent for WFS
Andrea Peri
aperi2007 at gmail.com
Mon Dec 19 22:24:54 PST 2016
Hi jukka,
The time low differenze could be to the use of a geopackage SQLite Instead
of a spatialite SQLite ?
A.
Il 19 dic 2016 23:34, "Rahkonen Jukka (MML)" <
jukka.rahkonen at maanmittauslaitos.fi> ha scritto:
> If I set "wfs_use_default_extent_for_getfeature" "yes"
> I see a difference
> [Tue Dec 20 00:28:37 2016].113723 msOGRFileWhichShapes: Setting spatial
> filter to -1e+300 -1e+300 1e+300 1e+300
> [Tue Dec 20 00:28:48 2016].950696 msOGRFileNextShape: Returning shape=9,
> tile=0
> However, this change does not make is fast, notice 11 seconds between
> WhichShapes and Next shape.
> -Jukka-
> *Lähettäjä:* Even Rouault [mailto:even.rouault at spatialys.com]
> *Lähetetty:* 20. joulukuuta 2016 0:27
> *Vastaanottaja:* mapserver-users at lists.osgeo.org
> *Kopio:* Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>
> *Aihe:* Re: [mapserver-users] Mapserver 7.0.3 and disabling default
> extent for WFS
> On lundi 19 décembre 2016 21:46:32 CET Rahkonen Jukka (MML) wrote:
> > Hi,
> > I am running Mapserver 7.0.3, I have a vector layer from a quite large
> > GeoPackage through OGR connection and I have set the LAYER METADATA item
> > "wfs_use_default_extent_for_getfeature" "no"
> > Still if I query GetFeature simply with &COUNT=1 I can see that the
> default
> > extent is used msOGRFileWhichShapes: Setting spatial filter to
> 19969.99999
> > 6597277.99999 749676.00001 7785300.00001 This makes count based request
> > pretty slow and it take about 15 second to get the first feature.
> > The documentation in http://mapserver.org/ogc/wfs_server.html says that
> this
> > option is supported "since MapServer 7.0.3" . So what could be wrong?
> Jukka,
> thanks for spotting my brain damage...
> In fact there are 2 issues :
> - a minor one: the debug message "Setting spatial filter..." was always
> displayed, even when the spatial filter wasn't applied
> - a major one: the logic to interpret the yes/no value of the setting was
> inverted (only when it is explicitly set fortunately, so that doesn't break
> existing mapfiles without the metadata item). I've fixed that, and thus
> modified the doc to advertize the feature only in 7.0.4. I guess I didn't
> notice that since I mixed it with other optimizations.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20161220/e6e2c91b/attachment.html>
