[mapserver-users] How can I get a customized MapCache folder structure with several dimensions as subfolders
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Feb 1 12:17:36 PST 2016
Hi Carola,
MS4W builds contain MapCache 1.4.0 (released in July). The next MS4W
release will include MapCache-master, but in fact we've recently been
hitting a compiler error with MapCache-master.
You can follow along this progress, in the associated MapCache ticket
(https://github.com/mapserver/mapcache/issues/139) as well as the MS4W
ticket for adding this support (http://ms4w.com/trac/ticket/39).
Thanks,
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2016-02-01 3:20 PM, thomas bonfort wrote:
> Carola,
> If you are willing to try out the master branch you can specify the keys
> in the disk template as {dim:dimname}, I.e. in your case:
> /path/{dim:year}/{dim:month}/etc..
> Make sure to read the migration-guide.txt as the syntax to define
> dimensions has changed a little.
> Thomas
> On Feb 1, 2016 12:33 PM, "Carola Kaiser" <ckaiser at cct.lsu.edu
> <mailto:ckaiser at cct.lsu.edu>> wrote:
> Hello,____
> __ __
> I am using MapServer 7.0 with MapCache and would like to customize
> the cache storage directory structure by using several dimensions as
> subfolders.____
> The goal is to get a cache folder structure like:____
> C:/ms4w/tmp/ms_tmp/cache/{YEAR}/{MONTH}/{DAY}/{z}/{y}/{x}.{ext}____
> __ __
> Here is what I have tried in my mapcache.xml file:____
> __1.__Use the <base></base> absolute path____
> __ __
> <cache name="disk" type="disk">____
> <base>C:/ms4w/tmp/ms_tmp/cache/</base>____
> </cache>____
> ____
> <source name="vmap0" type="wms"> ____
> …____
> </source>____
> ____
> <tileset name="test">____
> <source>vmap0</source>____
> <cache>disk</cache>____
> <grid>WGS84</grid>____
> <format>PNG</format>____
> <dimensions>____
> <dimension type="regex" name="YEAR"
> default="2016">^[0-9]{4}$</dimension>____
> <dimension type="regex" name="MONTH"
> default="00">^[0-9]{2}$</dimension>____
> <dimension type="regex" name="DAY"
> </dimensions>____
> </tileset>____
> __ __
> This works pretty nice but the final folder structure is:____
> C:/ms4w/tmp/ms_tmp/cache/test/WGS84/{YEAR}/{MONTH}/{DAY}/{z}/{y}/{x}.{ext}____
> How can I get rid of the test/WGS84 folders?____
> __ __
> __2.__Use the cache template tag____
> __ __
> <cache name="disk" type="disk" layout=”template”>____
> <template>C:/ms4w/tmp/ms_tmp/cache/{YEAR}/{MONTH}/{DAY}/{z}/{y}/{x}.{ext}</template>____
> </cache>____
> ____
> <source name="vmap0" type="wms">____
> …____
> </source>____
> ____
> <dimensions>____
> </dimensions>____
> </tileset>____
> __ __
> The template does only allow me to concatenate all dimensions like
> {YEAR}_{MONTH}_{DAY} but not to create a subfolder name from each
> dimension:____
> /{YEAR}/{MONTH}/{DAY}/____
> __ __
> Is it possible to customize the cache folder structure and how can I
> achieve this? Any help is very much appreciated!____
> __ __
> Thanks!____
> Carola____
> __ __
> ~~~~~~~~~~~~~~~~~~~~~~~~~~____
> Carola Kaiser, IT Consultant & GIS specialist____
> Center for Computation & Technology____
> Louisiana State University____
> e-mail: ckaiser at cct.lsu.edu <mailto:ckaiser at cct.lsu.edu>____
> CERA: http://coastalemergency.org____
> __ __
> __ __
