[mapserver-users] How can I get a customized MapCache folder structure with several dimensions as subfolders
Carola Kaiser ckaiser at cct.lsu.edu
Tue Feb 2 07:47:33 PST 2016
Thomas,
Thank you for getting back to me! These new features are exactly what I need. I will definitely give the new version  a try.
Thanks!
Carola
Carola Kaiser, IT Consultant & GIS specialist
Center for Computation & Technology
Louisiana State University
e-mail:  <mailto:ckaiser at cct.lsu.edu> ckaiser at cct.lsu.edu
CERA:  <http://coastalemergency.org> http://coastalemergency.org
From: thomas bonfort [mailto:thomas.bonfort at gmail.com]
Sent: Monday, February 1, 2016 1:20 PM
To: Carola Kaiser <ckaiser at cct.lsu.edu>
Cc: MapserverList OSGEO <mapserver-users at lists.osgeo.org>
Subject: Re: [mapserver-users] How can I get a customized MapCache folder structure with several dimensions as subfolders
Carola,
If you are willing to try out the master branch you can specify the keys in the disk template as {dim:dimname}, I.e. in your case:
/path/{dim:year}/{dim:month}/etc..
Make sure to read the migration-guide.txt as the syntax to define dimensions has changed a little.
Thomas
On Feb 1, 2016 12:33 PM, "Carola Kaiser" <ckaiser at cct.lsu.edu <mailto:ckaiser at cct.lsu.edu> > wrote:
Hello,
I am using MapServer 7.0 with MapCache and would like to customize the cache storage directory structure by using several dimensions as subfolders.
The goal is to get a cache folder structure like:
C:/ms4w/tmp/ms_tmp/cache/{YEAR}/{MONTH}/{DAY}/{z}/{y}/{x}.{ext}
Here is what I have tried in my mapcache.xml file:
1.       Use the <base></base> absolute path
   <cache name="disk" type="disk">
      <base>C:/ms4w/tmp/ms_tmp/cache/</base>
   </cache>
   <source name="vmap0" type="wms">
   </source>
   <tileset name="test">
      <source>vmap0</source>
      <cache>disk</cache>
      <grid>WGS84</grid>
      <format>PNG</format>
      <dimensions>
                <dimension type="regex" name="YEAR" default="2016">^[0-9]{4}$</dimension>
                 <dimension type="regex" name="MONTH" default="00">^[0-9]{2}$</dimension>
                <dimension type="regex" name="DAY" default="00">^[0-9]{2}$</dimension>
      </dimensions>
   </tileset>
This works pretty nice but the final folder structure is:
C:/ms4w/tmp/ms_tmp/cache/test/WGS84/{YEAR}/{MONTH}/{DAY}/{z}/{y}/{x}.{ext}
How can I get rid of the test/WGS84 folders?
2.       Use the cache template tag
   <cache name="disk" type="disk" layout=”template”>
      <template>C:/ms4w/tmp/ms_tmp/cache/{YEAR}/{MONTH}/{DAY}/{z}/{y}/{x}.{ext}</template>
   </cache>
   </source>
      <cache>disk</cache>
      <grid>WGS84</grid>
      <dimensions>
      </dimensions>
   </tileset>
The template does only allow me to concatenate all dimensions like {YEAR}_{MONTH}_{DAY} but not to create a subfolder name from each dimension:
Is it possible to customize the cache folder structure and how can I achieve this? Any help is very much appreciated!
Thanks!
Carola
mapserver-users mailing list
mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160202/57834c97/attachment-0001.html>
