[mapserver-users] WMS call with layer names containing a space.
TC Haddad
tchaddad at gmail.com
Thu Feb 4 08:51:16 PST 2016
This came up last year and I don't know if it was ever resolved:
https://lists.osgeo.org/pipermail/mapserver-users/2014-August/076870.html
https://lists.osgeo.org/pipermail/mapserver-users/2014-August/076886.html
On Thu, Feb 4, 2016 at 8:44 AM, Basques, Bob (CI-StPaul) <
bob.basques at ci.stpaul.mn.us> wrote:
> I was hoping there might be some tricky way of fooling MapServer by
> encoding, etc.
> bobb
> On Feb 4, 2016, at 10:39 AM, TC Haddad <tchaddad at gmail.com> wrote:
> When querying the TIGER server directly from a browser, the first and
> third styles of request both work, while the option with the "+" does not.
> So those are the 2 options the server will accept.
> I guess Mapserver prefers no space in a name, or a "+" to designate space,
> so you might be stuck.
> As a best practice, they really should have the version with a space in
> the Title rather than the Name, but you can't fix that from your end.
> On Thu, Feb 4, 2016 at 7:50 AM, Basques, Bob (CI-StPaul) <
>> All,
>> I’m trying to use this WMS:
>> http://tigerweb.geo.census.gov/arcgis/services/TIGERweb/tigerWMS_ACS2015/MapServer/WMSServer?
>> Specifically, two layers, “Census Tracts” and “Census Tracts Labels”
>> I can open the service in just about everything, except Mapserver as a
>> WMS client. I’m assuming the problem is in how MapServer is sending it’s
>> request.
>> I must be missing something obvious.
>> Thanks.
>> bobb
>> Call1:
>> http://gis.ci.stpaul.mn.us/datasets/BOUNDARIES/CENSUS/TRACTS/census_tracts_wms.map?FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=Census
>> <http://gis.ci.stpaul.mn.us/datasets/BOUNDARIES/CENSUS/TRACTS/census_tracts_wms.map?FORMAT=image/png&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=Census>
>> Tracts&_OLSALT=0.8675355401581306&SRS=EPSG%3A4326&BBOX=-93.239,44.892,-92.977,44.993&WIDTH=1557&HEIGHT=865
>> <http://gis.ci.stpaul.mn.us/datasets/BOUNDARIES/CENSUS/TRACTS/census_tracts_wms.map?FORMAT=image/png&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=Censu+Tracts&_OLSALT=0.48749308905327293&SRS=EPSG:200068&BBOX=550022.0283237,145619.55953757,593285.9716763,164199.44046243&WIDTH=971&HEIGHT=417>
>> error:
>> Parameter ‘layers’ contains unacceptable layer names
>> Call2 (use “+” for space):
>> http://gis.ci.stpaul.mn.us/datasets/BOUNDARIES/CENSUS/TRACTS/census_tracts_wms.map?FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=Census+Tracts&_OLSALT=0.8675355401581306&SRS=EPSG%3A4326&BBOX=-93.239,44.892,-92.977,44.993&WIDTH=1557&HEIGHT=865
>> <http://gis.ci.stpaul.mn.us/datasets/BOUNDARIES/CENSUS/TRACTS/census_tracts_wms.map?FORMAT=image/png&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=Census+Tracts&_OLSALT=0.8675355401581306&SRS=EPSG:4326&BBOX=-93.239,44.892,-92.977,44.993&WIDTH=1557&HEIGHT=865>
>> error:
>> Call3 (URL encoding “%20” ):
>> http://gis.ci.stpaul.mn.us/datasets/BOUNDARIES/CENSUS/TRACTS/census_tracts_wms.map?FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=Census%20Tracts&_OLSALT=0.8675355401581306&SRS=EPSG%3A4326&BBOX=-93.239,44.892,-92.977,44.993&WIDTH=1557&HEIGHT=865
>> <http://gis.ci.stpaul.mn.us/datasets/BOUNDARIES/CENSUS/TRACTS/census_tracts_wms.map?FORMAT=image/png&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=Census%20Tracts&_OLSALT=0.8675355401581306&SRS=EPSG:4326&BBOX=-93.239,44.892,-92.977,44.993&WIDTH=1557&HEIGHT=865>
>> error:
>> ##Mapfile
>> MAP
>> STATUS ON
>> LAYER
>> NAME "Census Tracts"
>> TYPE RASTER
>> STATUS DEFAULT
>> CONNECTION "
>> CONNECTIONTYPE WMS
>> METADATA
>> "wms_srs" "EPSG:4326"
>> "wms_name" "Census Tracts"
>> "wms_server_version" "1.1.1"
>> #"wms_server_version" "1.3.0"
>> "wms_format" "image/png24"
>> "ows_title" "Census Tracts"
>> #"gml_include_items" "all"
>> END
>> PROJECTION
>> "init=epsg:4326"
>> END
>> TEMPLATE "dummy"
>> END #layer
>> ##CONFIG "MS_ERRORFILE" "/tmp/trying2.txt"
>> ##DEBUG 5
>> END
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160204/93b800f3/attachment.html>
