[mapserver-users] Rendering of Symbols outside map window
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Mon Feb 15 08:44:13 PST 2016
I know. We use to account for that explicitly.
Sent: Monday, February 15, 2016 2:44 AM
To: Lime, Steve D (MNIT); Patrick Meis
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Rendering of Symbols outside map window
Steve,
I think the key part in the question is here:
" and the center point of the symbol is no longer inside the map window".
To my experience a symbol doesn't get drawn at all when the point which is symbolized is outside the requested extent (WMS mode at least).
To solve that I created the mentioned pull request.
Or do I miss something?
MArco
On 13-02-16 00:17, Lime, Steve D (MNIT) wrote:
This should already be happening. The drawing code traverses a layer's class/styles to commute a selection and clipping rectangle that is larger than the map extent.
From: mapserver-users [mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org>] on behalf of mdprive [deduikertjes at xs4all.nl<mailto:deduikertjes at xs4all.nl>]
Sent: Friday, February 12, 2016 4:15 PM
To: Patrick Meis
Cc: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Hi Patrick,
i've submitted a pull request for extending the map by a buffer and then clipping it, so that partial symbols on the edge get rendered as well (wms non tiled mode).
maybe you can build from sources and use this patch to solve your problem.
marco
Op 11 feb. 2016 om 21:54 heeft Ambrogio Foletti <<mailto:afoletti at gmail.com>afoletti at gmail.com<mailto:afoletti at gmail.com>> het volgende geschreven:
Hello Patrick,
if you are using PostGIS as datasource, I would solve the problem by integrating a st_buffer in the DATA element itself ;) The added bonus is that you will get the attribute values from a GetFeatureInfo (if implemented) in the whole buffer zone.
If not, you can try to use tile mode, and add some metabuffer (see mapserver doc<http://mapserver.org/output/tile_mode.html>)
Cheers!
A. Foletti
2016-02-05 10:58 GMT+01:00 Patrick Meis <Meis at stadt-muenster.de<mailto:Meis at stadt-muenster.de>>:
Hallo,
i have stumbled on a problem.
I am simulating a buffering of point-data with the help of symbols, which I have set to
sizeunit = meters
size = 760
These rather big symbols disappear from my map when I zoom in and
the center point of the symbol is no longer inside the map window.
But a significant part of the symbol should still be displayed.
Is there any possibility of extending the rendered map, so that the symbols of my points
are still rendered even when they are outside my map window?
Greetz
Patrick
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160215/cd5e7bed/attachment.html>
