[mapserver-users] Label not Displaying at Edge of Map Extent
Michele Toma michele.toma at airborne.aero
Tue Feb 23 17:14:21 PST 2016
Hi everyone,
I am having an issue with getting a label to display when it is near the edge of the map extent. From what I have seen, when I attach the style for the icon to the label object, the label does not display. However, if I remove the style for the icon from the label object, it does display. Is this an issue with MapServer 7 or the settings that I have used?
Version Information:
[root at Map18-03 cgi-bin]# ./mapserv -v
MapServer version 7.0.0 OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=FASTCGI SUPPORTS=GEOS INPUT=JPEG INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Below is the map file to reproduce the issue. Please note that there are two layers - one without the icon style attached, and one with the icon style attached. The layer without the icon style attached has been turned on while the other is off.
MAP
  EXTENT -87.919802 0.000000 72.177555 90.000000
  SIZE 1280 720
  IMAGECOLOR 140 140 140
  SYMBOL
    NAME 'Airport'
    TYPE ELLIPSE
    POINTS 1 1 END
    FILLED true
  END
  LAYER
    NAME "Label does display (no icon)"
    TYPE POINT
    FEATURE
        POINTS
          -87.9 41.983333
        END
    END
    PROJECTION
      "proj=latlong"
      "ellps=WGS84"
    END # PROJECTION
    STATUS DEFAULT
    CLASS
      TEXT 'Label'
      LABEL
        TYPE BITMAP
        SIZE 20
        COLOR 255 255 255
        PARTIALS FALSE
        POSITION AUTO
        PRIORITY 10
      END # LABEL
    END # CLASS
  END # LAYER
  LAYER
    NAME "Label does not display (with icon)"
    TYPE POINT
    FEATURE
        POINTS
          -87.9 41.983333
        END
    END
    PROJECTION
      "proj=latlong"
      "ellps=WGS84"
    END # PROJECTION
    STATUS OFF
    CLASS
      TEXT 'Label'
      LABEL
        TYPE BITMAP
        SIZE 20
        COLOR 255 255 255
        PARTIALS FALSE
        POSITION AUTO
        PRIORITY 10
        STYLE
          SYMBOL "Airport"
          COLOR 0 255 0
          OUTLINECOLOR 0 0 0
          SIZE 20
        END # STYLE
      END # LABEL
    END # CLASS
  END # LAYER
END
Thank you,
Michele Toma
michele.toma at airborne.aero<mailto:michele.toma at airborne.aero>
www.airborne.aero
[New Small2]
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160224/7b2f22bd/attachment.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160224/7b2f22bd/attachment.jpg>
