[mapserver-users] kml superoverlays
Even Rouault
even.rouault at spatialys.com
Wed Jan 13 08:32:07 PST 2016
Le mercredi 13 janvier 2016 17:15:12, Páll Péter Hunor a écrit :
> Hi,
> Does mapserver support raster layers using kml superoverlays as data
> source, similar to shapefile based tileindexes?
> I did not find any solution, but I still might exist...
> Thanks in advance.
GDAL supports opening kml superoverlays file as rasters (probably with some
caveats), so you can try adding DATA your.kml or your.kmz in the mapfile.
(no docs apart mentionning it in
http://gdal.org/formats_list.html )
> Regards,
> Hunor
http://www.spatialys.com
