[mapserver-users] running out of colors in PC256 output
Richard Greenwood
richard.greenwood at gmail.com
Sat Jan 16 15:12:11 PST 2016
Thanks Steve. Yet another beer that I owe you! I've used Photoshop create
palettes for source imagery a long time ago but didn't think of it for the
output.
Hope you're doing well, and as always, I appreciate your help.
Rich
On Sat, Jan 16, 2016 at 8:29 AM, Lime, Steve D (MNIT) <
Steve.Lime at state.mn.us> wrote:
> You can create a predefined palette and use that. Here's an example
> definition:
> OUTPUTFORMAT
> NAME png8
> DRIVER "AGG/PNG"
> MIMETYPE "image/png"
> IMAGEMODE RGB
> EXTENSION "png"
> FORMATOPTION "INTERLACE=OFF"
> FORMATOPTION "PALETTE_FORCE=TRUE"
> FORMATOPTION "PALETTE=/usr/local/mapserver/shared/my.palette" # needs
> to be a full path
> END
> where the palette file is just a text file with a bunch of RGB triplets:
> 201,222,252
> 40,172,218
> I've used PhotoShop to take sample MapServer 24-bit output that is
> representative of maps as a whole (shows all feature types and labeling
> scenarios) and create an 8-bit GIF. That software does a nice job of color
> reduction but I'm sure there are other ways. Then you can use gdalinfo to
> extract the palette information. I have a little perl script that parses
> the gdalinfo output if you're interested.
> Steve
> *From:* mapserver-users [mapserver-users-bounces at lists.osgeo.org] on
> behalf of Richard Greenwood [richard.greenwood at gmail.com]
> *Sent:* Friday, January 15, 2016 8:43 PM
> *To:* mapserver
> *Subject:* [mapserver-users] running out of colors in PC256 output
> I'm running into more or less the same problem described in this 12 year
> old ticket:
> https://trac.osgeo.org/mapserver/ticket/397
> In my case black truetype font labels will be rendered in dark green or
> similar when there are a lot of colors in accompanying vector layers with
> anit-aliasing or opacity. I think the 256 color palette gets used up before
> the labels are rendered.
> I don't want to go to full RGB output because the image sizes are so much
> larger. If I put a black feature into one of the layers it seems to add it
> to the palette and then the black labels are render correctly in black. But
> that seems pretty kludgy.
> Any other suggestions?
> Thanks
> Richard W. Greenwood, PLS
> www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160116/1f55686d/attachment.html>
