[mapserver-users] Map file, Label WRAP Function in mapbook removes character it
Schepers, Benjamin
schepers at rvr-online.de
Fri Jul 1 00:14:02 PDT 2016
Hi Carrie,
in my opinion the easiest way would be converting the data to spatialite-DB (you get a lot of database-functions in a file based-DB - no client-server-architecture, just a file; at best you use ogr2ogr or QGIS for conversion) and then use replace function in your SQL-QUERY
i.e. to dynamically insert pipe "|" as wrap-character it should look like that (fieldname is "parcel_no"):
SELECT *, replace(parcel_no, '.', '.|') AS parcel_no_wrap FROM parcel_table
If you have a shapefile and your parcel-no have a strict pattern (ie. 2digits.3digits.4digits) then it should also be possible to use OGR generic "concat" and "substring"-function, which were introduced with GDAL 1.8 (according to documentation at http://www.gdal.org/ogr_sql.html#ogr_sql_flist_ops and http://www.gdal.org/ogr_sql.html#ogr_sql_functions):
Example, also with pipe as wrap-character:
SELECT *, CONCAT(SUBSTR(parcel_no,1,2),'.|',SUBSTR(parcel_no,4,3),'.|',SUBSTR(parcel_no,8,4)) AS parcel_no_wrap FROM parcel_table
In both examples the new virtual field "parcel_no_wrap" could be used for displaying text with wrap character...
Sincerely,
Benjamin Schepers
Von: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag von Mark Volz
Gesendet: Donnerstag, 30. Juni 2016 15:09
An: mapserver-users at lists.osgeo.org
Betreff: Re: [mapserver-users] Map file, Label WRAP Function in mapbook removes character it
Carrie,
Our trick is to wrap on a character that you would otherwise not normally see in the string.
LAYER
CLASS
TEXT ([LastName] * [PIN]) #overrides LABELITEM
LABEL
WRAP "*"
END #Parcel Label
END #Parcel Class
END #Parcel Layer
Sincerely,
Mark Volz, GISP
-----Original Message-----
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of mapserver-users-request at lists.osgeo.org
Sent: Wednesday, June 29, 2016 11:04 AM
To: mapserver-users at lists.osgeo.org
Subject: mapserver-users Digest, Vol 101, Issue 37
Send mapserver-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://lists.osgeo.org/mailman/listinfo/mapserver-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
mapserver-users-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific than "Re: Contents of mapserver-users digest..."
Today's Topics:
1. Map file, Label WRAP Function in mapbook removes character it
is wrapping on. (Carrie Quast)
Message: 1
Date: Wed, 29 Jun 2016 15:58:59 +0000
From: Carrie Quast <Carrie.Quast at co.brown.mn.us>
To: "'mapserver-users at lists.osgeo.org'"
<mapserver-users at lists.osgeo.org>
Subject: [mapserver-users] Map file, Label WRAP Function in mapbook
removes character it is wrapping on.
Message-ID: <77b9eefcc9264bddb77bd9a85bd037e1 at MSEXCHANGE1.bc.local>
Content-Type: text/plain; charset="utf-8"
Hello - I'm working on updating my .MAP Documents to Mapserver 7.0.1.
I'm trying to get the labels in my Parcel Layer to wrap on the decimal point (example 002.001.001.01.010) to make for a better a fit. I'm using the WRAP function, which works wonderfully , except it removes the character I am wrapping on. In this case, the point (.) In my parcel numbers.
Each of the numbers should have a decimal between it. Any idea of how to get the line to wrap on a character, but also keep it in the displayed label? The MAXLENGTH works well too, but still removes all decimal points.
I'm using Mapserver 7.0.1 with GeoMoose 2.9
Thank You - Carrie Quast, Brown County MN GIS Specialist
[cid:image002.png at 01D1D1F5.3D5294F0]
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160629/8bda4b92/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160629/8bda4b92/attachment.png>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160629/8bda4b92/attachment-0001.png>
Subject: Digest Footer
End of mapserver-users Digest, Vol 101, Issue 37
