[mapserver-users] SOS SERVER: how to define in the ".map" the "FeatureOfInterest" attribute
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Jun 14 12:31:44 PDT 2016
Hello,
When you asked about SOS server, I took the time today to update the SOS
Server document (http://mapserver.org/ogc/sos_server.html), as it had a
lot of old links. If you ever notice links or text that needs fixing in
the docs, please file a ticket (https://github.com/mapserver/docs/issues).
In terms of the "FeatureOfInterest" parameter, it is part of a
GetObservation request
(http://mapserver.org/ogc/sos_server.html#getobservation-request), so it
wouldn't be set in the .map file, but instead you (the SOS client, such
as OpenLayers) would include the parameter as part of the GetObservation
request. You can read more about that FeatureOfInterest parameter on
page 29 of the SOS 1.0.0 specification document (download that from
http://www.opengeospatial.org/standards/sos).
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2016-06-14 9:57 AM, Hergest wrote:
> Hi!
> I'm creating a SOS SERVER with Mapserver 7.0.1.
> I don't know how to define in the ".map" the "FeatureOfInterest"
> attribute. Always it appears as "transient" in GetFeatureInfo responding
> XML (you can try it at
> http://hergest.synology.me/sos?SERVICE=SOS&REQUEST=GetCapabilities ).
> I read the document at "http://mapserver.org/es/ogc/sos_server.html",
> but no idea...
> Thanks in advance.
> My definition map:
> MAP
> NAME "SOS_DEMO"
> STATUS ON
> SIZE 300 300
> EXTENT -180 -90 180 90
> UNITS METERS
> IMAGECOLOR 255 255 0
> IMAGETYPE png
> WEB
> IMAGEPATH "/ms4w/tmp/ms_tmp/"
> IMAGEURL "/ms_tmp/"
> METADATA
> "sos_onlineresource" "http://hergest.synology.me/sos" ## REQUIRED
> "sos_title" "Servidor SOS de prueba" ## Recommended
> "sos_srs" "EPSG:4326" ## REQUIRED
> "sos_enable_request" "*" # Necessary
> END
> END
> PROJECTION
> "init=epsg:4326"
> END
> LAYER
> NAME "test_sos_layer"
> METADATA
> "sos_procedure_item" "StationId"
> "sos_offering_id" "Estaciones" ## REQUIRED
> "sos_observedproperty_id" "datos_station" ## REQUIRED
> "sos_describesensor_url" "http://some/url/NS01EE0014.xml" ##
> REQUIRED (POR HACER!)
> "sos_offering_name" "Estaciones"
> "sos_timeitem" "timestamp"
> "sos_offering_description" "Datos de estaciones"
> "sos_offering_intendedapplication" "Natural resource planning"
> ## Texto opcional
> END
> TYPE POINT
> STATUS ON
> CONNECTIONTYPE OGR
> CONNECTION "sos_data.ovf"
> DATA "sos_data"
> PROJECTION
> "init=epsg:4326"
> END
> CLASS
> COLOR 255 0 0
> SIZE 10
> END
> END
> END #map
