[mapserver-users] Rendering of adjacent dashed lines
Ziegler Stefan
Stefan.Ziegler at bd.so.ch
Fri Jun 17 07:27:20 PDT 2016
Then I wasn't propably clear about the problem. I can get the desired effect in QGIS. The line symbol is a combination of two line symbols. One is dashed, one is solid.
Regards
Stefan
Sent from my iPhone
> On 17 Jun 2016, at 16:20, thomas bonfort <thomas.bonfort at gmail.com> wrote:
> Hi Stefan,
> Unfortunately no. When I said "impossible" I meant it in the general
> case, not for MapServer specifically.
> Regards,
> thomas
>> On 17 June 2016 at 16:17, Ziegler Stefan <Stefan.Ziegler at bd.so.ch> wrote:
>> Hi Thomas
>> Would it be possible to fund such a feature?
>> Stefan
>> Sent from my iPhone
>>> On 17 Jun 2016, at 16:05, thomas bonfort <thomas.bonfort at gmail.com> wrote:
>>> Stefan,
>>> There is no trick/workaround for this aside from preprocessing your
>>> data to merge adjacent lines into one. In the general case what you
>>> are aiming for is impossible as your adjacent lines will have
>>> different lengths but will be using a fixed length dash pattern.
>>> thomas
>>>> On 17 June 2016 at 12:38, Ziegler Stefan <Stefan.Ziegler at bd.so.ch> wrote:
>>>> Hi
>>>> I'm trying to render some lines with a pattern. This works and looks great as long as the lines are not adjacent. When the lines share a common border the dashed lines may look ugly since one dashed line is rendered on top of the other rendered dashed line. I tried to add a white solid line under the dashed line:
>>>> CLASS
>>>> STYLE
>>>> COLOR 255 255 255
>>>> WIDTH 2
>>>> LINECAP BUTT
>>>> END
>>>> STYLE
>>>> COLOR 0 0 0
>>>> WIDTH 2
>>>> LINECAP BUTT
>>>> PATTERN 20 4 2 4 2 4 END
>>>> END
>>>> END
>>>> But the behaviour is still the same. Is there a trick/workaround for this? I'm using MapServer 7.0.1.
>>>> Best regards
>>>> Stefan Ziegler
>>>> Freundliche Grüsse
>>>> Stefan Ziegler
>>>> Kantonsgeometer / Leiter Amt für Geoinformation
>>>> Rötistrasse 4
>>>> 4500 Solothurn
>>>> Telefon +41 32 627 75 96
>>>> Telefax +41 32 627 75 98
>>>> stefan.ziegler at bd.so.ch
>>>> http://www.so.ch
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
