[mapserver-users] MapServer Tile Indexes
Schepers, Benjamin
schepers at rvr-online.de
Tue Jun 21 06:09:00 PDT 2016
Hi all,
another try for troubleshooting could be building a VRT (use gdalbuildvrt - it produces some kind of "advanced raster-catalogue"). If you have faulty data, there would be a chance, that you get some error-messages, which dataset produces problems...
This VRT - if everything went fine - could also be the source to build a large TIFF-Dataset, similar to what Jukka recommended.
Some good compression-parameters for elevation-data in large GeoTIFF would be to use gdal_translate with "-of GTiff -ot Float32 -co BIGTIFF=YES -co COMPRESS=DEFLATE -co TILED=YES" (if you use GDAL 2.1 "-co NUM_THREADS=ALL_CPUS" will speed up this process, as it uses all cpu-cores).
You should also think about overviews for small scales. Interesting post from Paul Ramsey:
http://blog.cleverelephant.ca/2015/02/geotiff-compression-for-dummies.html - This is about compressing Aerial Images, but it points you into the right direction (remind my compression parameters above for DEM-data).
Such compressed dataset will be presented by mapserver amazingly fast. I've got a dataset with similar dimensions but 10m res which is about 100MB --> plain upscaling to your resolution would produce a dataset about 10-15GB, but this depends on your data...
Cheers
Benjamin
Luftbild und Geoinformationssysteme
Regionalverband Ruhr
Kronprinzenstraße 35
45128 Essen
Germany
luftbilder.geoportal.ruhr
-----Ursprüngliche Nachricht-----
Von: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag von Jeff McKenna
Gesendet: Dienstag, 21. Juni 2016 13:13
An: mapserver-users at lists.osgeo.org
Betreff: Re: [mapserver-users] MapServer Tile Indexes
Hello,
MapServer should definitely be able to handle your dataset, it is not large.
If I was in your shoes, here is what I would do:
- try to see more debug information (follow the steps and examples in
http://www.mapserver.org/optimization/debugging.html)
-- set in your mapfile: CONFIG "CPL_DEBUG" "ON"
-- shp2img -m my.map -o test.png -all_debug 5
-- mapserv -nh "QUERY_STRING=map=c:/ms4w/apps/my.map&mode=map"
- it does sound like you have a faulty GRID file. Start from your
single working tileindex, then add in maybe 5 more rasters into your
index and retry; if it works, add in another 5 etc.
Sometimes the best way to solve this is the hard way.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2016-06-21 6:12 AM, Wright, Simon M. wrote:
> Dear All
> I’m trying to use the MapServer Tile Indexes to create a map service,
> and ultimately a WMS, of some DSM data but am getting an Internal Server
> Error.
> The DSM data are organised as 466 5 × 5 km rasters with a resolution of
> 1 × 1 m with a total size of 69.2 GB. The data format is Esri ASCII GRID.
> To test the use of Tile Indexes in MapServer I used the gdaltindex to
> create an index shapefile for just twenty of the 5 × 5 km rasters and
> created a basic map file:
> MAP
> IMAGETYPE PNG
> EXTENT 240000 100000 250000 150000
> SIZE 400 2000
> PROJECTION
> "init=epsg:27700"
> END
> LAYER
> NAME "tiled-rasters"
> STATUS ON
> TILEINDEX
> "/datastore/b81071f2-85b3-4e31-8506-cabe899f989a/b81071f2-85b3-4e31-8506-cabe899f989a_copy/index_file"
> TILEITEM "location"
> TYPE RASTER
> PROJECTION
> "init=epsg:27700"
> END
> END
> END
> When I request an image of the map with the URL
> http://localhost:8080/cgi-bin/mapserv?map=/vagrant/maps/tiled-rasters.map&layer=tiled-rasters&mode=map
> I get an “Internal Server Error”.
> Therefore I created a second index shapefile using the gdaltindex tool
> that only contained one of the 5 × 5 km rasters and updated the map file
> to point to the second index shapefile. When I request an image of the
> map I can see an image of the DSM data as expected.
> Therefore, am I asking too much of the tile indexing approach in
> MapServer to work against a massive dataset – 69.2 GB in 466 raster
> datasets – or have MapServer users been able to get tile indexing too
> work in MapServer against large data volumes and can provide some guidance.
> Many thanks in advance of any help that MapServer users can offer.
> Best wishes, Simon.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
