[mapserver-users] zipped shapefile
lars.schylberg at blixtmail.se
Wed Jun 22 14:37:27 PDT 2016
I guess that You need a layer definition in a DATA statement.
LAYER ... CONNECTIONTYPE OGR CONNECTION "<datasource_name>" DATA "<layer_definition>" ...END
http://mapserver.org/input/vector/ogr.html
/Lars S.
-----Originalmeddelande-----
> Från: lagrange123 <lagrange at ldeo.columbia.edu>
> Till: mapserver-users at lists.osgeo.org
> Datum: 2016-06-22 23:13
> Ämne: [mapserver-users] zipped shapefile
> Hi,
> I have a bunch of shapefiles in zip format for disk space reasons. And I
> want to be able to server their contents with mapserver. Is this possible?
> I was thinking that I could use CONNECTIONTYPE OGR. And then, since gdal/ogr
> can read a zipped data source (per
> https://trac.osgeo.org/gdal/wiki/UserDocs/ReadInZip), this would enable
> mapserver to serve such a data source. However, I am not having much luck,
> and I don't know if this is even supported in mapserver.
> My layer definition is:
> LAYER
> NAME "my_shapefile"
> CONNECTIONTYPE OGR
> CONNECTION "/vsizip/path/to/file.zip"
> TYPE POLYGON
> STATUS ON
> END
> View this message in context: http://osgeo-org.1560.x6.nabble.com/zipped-shapefile-tp5272896.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160622/c3b2b4a1/attachment-0001.html>
