[mapserver-users] zipped shapefile
Michael Smith
michael.smith.erdc at gmail.com
Wed Jun 22 15:52:34 PDT 2016
You need to include the name of the shapefile in the DATA statement, eg
DATA "/vsizip/myzipfile.zip/shapefile.shp"
Mike
Michael Smith
US Army Corps
Remote Sensing GIS/Center
michael.smith at usace.army.mil
-----Original Message-----
From: mapserver-users <mapserver-users-bounces at lists.osgeo.org> on behalf
of Jeff McKenna <jmckenna at gatewaygeomatics.com>
Date: Wednesday, June 22, 2016 at 6:46 PM
To: <mapserver-users at lists.osgeo.org>
Subject: Re: [mapserver-users] zipped shapefile
>I'm also unable to get this to work. I agree that it should (with the
>layer specified in the "DATA" statement), but I can't seem to get
>MapServer 7.0.1 to draw a map. The error message is quite generic:
> OGROpen(/vsizip/test.zip)
> msOGRFileOpen(): OGR error. Open failed for OGR connection in layer
>'test'. File not found or unsupported format.
>I believe you have found a nice enhancement. I think you should file
>this in the issue tracker: https://github.com/mapserver/mapserver/issues
>-jeff
>Jeff McKenna
>MapServer Consulting and Training Services
>http://www.gatewaygeomatics.com/
>On 2016-06-22 5:57 PM, lagrange123 wrote:
>> Hi,
>> I have a bunch of shapefiles in zip format for disk space reasons. And I
>> want to be able to server their contents with mapserver. Is this
>>possible?
>> I was thinking that I could use CONNECTIONTYPE OGR. And then, since
>>gdal/ogr
>> can read a zipped data source (per
>> https://trac.osgeo.org/gdal/wiki/UserDocs/ReadInZip), this would enable
>> mapserver to serve such a data source. However, I am not having much
>>luck,
>> and I don't know if this is even supported in mapserver.
>> My layer definition is:
>> LAYER
>> NAME "my_shapefile"
>> CONNECTIONTYPE OGR
>> CONNECTION "/vsizip/path/to/file.zip"
>> TYPE POLYGON
>> STATUS ON
>> END
>_______________________________________________
>mapserver-users mailing list
>http://lists.osgeo.org/mailman/listinfo/mapserver-users
