[mapserver-users] zipped shapefile
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Jun 23 04:33:41 PDT 2016
On 2016-06-23 3:49 AM, Even Rouault wrote:
> Definitely not in the DATA that must be a layer name or SQL SELECT, but in CONNECTION.
> It is important to put the absolute path, as the SHAPEPATH directive will have no effect on
> a /vsizip/ filename. As Mike raised, it is recommended to put the filename of the shape too.
> (you may omit it if the .shp is at the root of the .zip and there's no other "extra" file than the ones
> expected for a shapefile. When you omit it, the zip is recognized as a directory and it is the
> same logic as doing ogrinfo on a directory that is applied. Will work with directory of shapefiles
> and .tab/.mif for example)
Thank you Even, my issue was the full path requirement. I will document
this now.
Below is my working layer (with MS4W 3.1.4 / MapServer 7.0.1) :
LAYER
NAME "testzip"
TYPE POLYGON
STATUS ON
CONNECTIONTYPE OGR
CONNECTION "/vsizip/D:/ms4w/apps/test/test.zip"
DATA "test"
CLASS
NAME "test"
STYLE
COLOR 240 240 240
OUTLINECOLOR 199 199 199
END
END
END # layer
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
