[mapserver-users] Building Mapserver - missing strlcat... methods
Michael Schulz
mandschulz at googlemail.com
Fri Jun 24 05:12:24 PDT 2016
Hi Thomas,
thanks for your help, I was too blind to realise that error underneath the
python warning. Shame on me: beginners error php-devel not installed...
Thanks, Michael
2016-06-24 13:53 GMT+02:00 thomas bonfort <thomas.bonfort at gmail.com>:
> Your error is somehow coming from the php installation/configuration.
> Check your log messages for something there.
> On 24 June 2016 at 13:49, Michael Schulz <mandschulz at googlemail.com>
> wrote:
> > Hi Thomas,
> > I'm pretty sure it is. Just did a rm -rf * on the build dir, and then
> this:
> > :/usr/local/src/mapserver-7.0.1/build # cmake ..
> > -DCMAKE_INSTALL_PREFIX=/opt/mapserver-7.0.1
> > -DCMAKE_PREFIX_PATH=/opt/gdal-trunk -DWITH_CLIENT_WFS=ON
> > -DWITH_CLIENT_WMS=ON -DWITH_CURL=ON -DWITH_SOS=ON
> > -DWITH_PHP=ON -DWITH_PYTHON=ON -DWITH_SVGCAIRO=ON
> > -DWITH_ORACLESPATIAL=ON -DWITH_HARFBUZZ=0 -DWITH_FRIBIDI=0
> > -DWITH_FCGI=0
> > -- The C compiler identification is GNU 4.3.4
> > -- The CXX compiler identification is GNU 4.3.4
> > -- Check for working C compiler: /usr/bin/cc
> > -- Check for working C compiler: /usr/bin/cc -- works
> > -- Detecting C compiler ABI info
> > -- Detecting C compiler ABI info - done
> > -- Check for working CXX compiler: /usr/bin/c++
> > -- Check for working CXX compiler: /usr/bin/c++ -- works
> > -- Detecting CXX compiler ABI info
> > -- Detecting CXX compiler ABI info - done
> > -- Looking for strrstr
> > -- Looking for strrstr - not found
> > -- Looking for strcasecmp
> > -- Looking for strcasecmp - found
> > -- Looking for strcasestr
> > -- Looking for strcasestr - found
> > -- Looking for strdup
> > -- Looking for strdup - found
> > -- Looking for strlcat
> > -- Looking for strlcat - not found
> > -- Looking for strlcpy
> > -- Looking for strlcpy - not found
> > -- Looking for strlen
> > -- Looking for strlen - found
> > -- Looking for strncasecmp
> > -- Looking for strncasecmp - found
> > -- Looking for vsnprintf
> > -- Looking for vsnprintf - found
> > -- Looking for lrintf
> > -- Looking for lrintf - found
> > -- Looking for lrint - found
> > -- Looking for dlfcn.h
> > -- Looking for dlfcn.h - found
> > -- Performing Test HAVE_SYNC_FETCH_AND_ADD
> > -- Performing Test HAVE_SYNC_FETCH_AND_ADD - Success
> > -- Found ZLIB: /usr/lib64/libz.so (found version "1.2.7")
> > -- Found PNG: /usr/lib64/libpng.so (found version "1.2.31")
> > -- Found JPEG: /usr/lib64/libjpeg.so
> > -- Found Freetype: /usr/lib64/libfreetype.so
> > -- Found PROJ: /usr/lib64/libproj.so
> > -- Looking for iconv
> > -- Looking for iconv - found
> > -- Found iconv library:
> > -- Found PkgConfig: /usr/bin/pkg-config (found version "0.23")
> > -- checking for module 'cairo'
> > -- found cairo, version 1.8.8
> > -- Found CAIRO: /usr/lib64/libcairo.so
> > ORACLE_HOME=/home/oracle/app/oracle/product/12.1.0/client_1
> > -- Found ORACLE:
> /home/oracle/app/oracle/product/12.1.0/client_1/lib/libclntsh.so;/home/oracle/app/oracle/product/12.1.0/client_1/lib/libocci.so;/home/oracle/app/oracle/product/12.1.0/client_1/lib/libnnz12.so
> > -- Found GEOS: /usr/lib64/libgeos_c.so
> > -- Found POSTGRESQL: /usr/lib64/libpq.so
> > -- Looking for PQserverVersion in pq
> > -- Looking for PQserverVersion in pq - found
> > -- Found GDAL: /opt/gdal-trunk/lib/libgdal.so
> > -- Found SVG: /usr/local/lib/libsvg.so
> > -- Found SVGCAIRO: /usr/local/lib/libsvg-cairo.so
> > -- Found CURL: /usr/lib64/libcurl.so (found version "7.19.7")
> > -- Found LibXml2: /usr/lib64/libxml2.so (found version "2.7.6")
> > -- Performing Test GIF_GifFileType_UserData
> > -- Performing Test GIF_GifFileType_UserData - Success
> > -- Found GIF: /usr/lib64/libgif.so (found version "4")
> > -- Found SWIG: /usr/bin/swig (found version "1.3.36")
> > -- Found PythonInterp: /usr/bin/python (found version "2.6.9")
> > CMake Warning (dev) at mapscript/python/CMakeLists.txt:42
> > (get_target_property):
> > Policy CMP0026 is not set: Disallow use of the LOCATION target
> property.
> > Run "cmake --help-policy CMP0026" for policy details. Use the
> > cmake_policy
> > command to set the policy and suppress this warning.
> > The LOCATION property should not be read from target
> "_pythonmapscript".
> > Use the target name directly with add_custom_command, or use the
> generator
> > expression $<TARGET_FILE>, as appropriate.
> > This warning is for project developers. Use -Wno-dev to suppress it.
> > CMake Error at mapscript/php/CMakeLists.txt:31 (install):
> > install TARGETS given no LIBRARY DESTINATION for module target
> > "php_mapscript".
> > -- * Summary of configured options for this build
> > -- * Mandatory components
> > -- * png: /usr/lib64/libpng.so
> > -- * jpeg: /usr/lib64/libjpeg.so
> > -- * freetype: /usr/lib64/libfreetype.so
> > -- * Optional components
> > -- * GDAL: /opt/gdal-trunk/lib/libgdal.so
> > -- * OGR: /opt/gdal-trunk/lib/libgdal.so
> > -- * GIF: /usr/lib64/libgif.so
> > -- * MYSQL: disabled
> > -- * FRIBIDI: disabled
> > -- * HARFBUZZ: disabled
> > -- * CAIRO: /usr/lib64/libcairo.so
> > -- * SVGCAIRO: /usr/local/lib/libsvg-cairo.so
> > -- * RSVG: disabled
> > -- * CURL: /usr/lib64/libcurl.so
> > -- * PROJ: /usr/lib64/libproj.so
> > -- * PIXMAN: disabled
> > -- * LIBXML2: /usr/lib64/libxml2.so
> > -- * POSTGIS: /usr/lib64/libpq.so
> > -- * GEOS: /usr/lib64/libgeos_c.so
> > -- * FastCGI: disabled
> > -- * Oracle Spatial:
> > -- * Exempi XMP: disabled
> > -- * Optional features
> > -- * WMS SERVER: ENABLED
> > -- * WFS SERVER: ENABLED
> > -- * WCS SERVER: ENABLED
> > -- * SOS SERVER: ENABLED
> > -- * WMS CLIENT: ENABLED
> > -- * WFS CLIENT: ENABLED
> > -- * ICONV: ENABLED
> > -- * Thread-safety support: disabled
> > -- * KML output: disabled
> > -- * Z+M point coordinate support: disabled
> > -- * XML Mapfile support: disabled
> > -- * Mapscripts
> > -- * Python: ENABLED
> > -- * PHP: ENABLED
> > -- * PERL: disabled
> > -- * RUBY: disabled
> > -- * JAVA: disabled
> > -- * C#: disabled
> > -- * V8 Javascript: disabled
> > -- * Apache Module (Experimental): disabled
> > -- Will install files to /opt/mapserver-7.0.1
> > -- Will install libraries to /opt/mapserver-7.0.1/lib
> > -- Configuring incomplete, errors occurred!
> > See also
> "/usr/local/src/mapserver-7.0.1/build/CMakeFiles/CMakeOutput.log".
> > See also
> "/usr/local/src/mapserver-7.0.1/build/CMakeFiles/CMakeError.log".
> > Thanks, Michael
> > 2016-06-24 11:46 GMT+02:00 thomas bonfort <thomas.bonfort at gmail.com>:
> >> The str* missising functions should not be an issue, those are just
> >> checks to see if we shall be providing our own implementation. Are you
> >> sure you posted the whole cmake log ?
> >> thomas
> >> On 24 June 2016 at 11:31, Michael Schulz <mandschulz at googlemail.com>
> >> wrote:
> >> > Hi Thomas,
> >> > nope, unfortunately not. Deleted everything, rerun cmake, still got
> the
> >> > same
> >> > errors (strsstr, strlcat, strlcpy not found). This is one part of
> >> > CMakeError.log:
> >> > Determining if the function strrstr exists failed with the following
> >> > output:
> >> > Change Dir: /usr/local/src/mapserver-7.0.1/build/CMakeFiles/CMakeTmp
> >> > Run Build Command:"/usr/bin/gmake" "cmTryCompileExec1997038117/fast"
> >> > /usr/bin/gmake -f CMakeFiles/cmTryCompileExec1997038117.dir/build.make
> >> > gmake[1]: Entering directory
> >> > `/usr/local/src/mapserver-7.0.1/build/CMakeFiles/CMakeTmp'
> >> > /usr/bin/cmake -E cmake_progress_report
> >> > /usr/local/src/mapserver-7.0.1/build/CMakeFiles/CMakeTmp/CMakeFiles 1
> >> > Building C object
> >> > CMakeFiles/cmTryCompileExec1997038117.dir/CheckFunctionExists.c.o
> >> > /usr/bin/cc -DCHECK_FUNCTION_EXISTS=strrstr
> >> > -I/usr/local/src/mapserver-7.0.1/build/CMakeFiles/CMakeTmp/math.h
> -o
> >> > CMakeFiles/cmTryCompileExec1997038117.dir/CheckFunctionExists.c.o -c
> >> > /usr/share/cmake/Modules/CheckFunctionExists.c
> >> > Linking C executable cmTryCompileExec1997038117
> >> > /usr/bin/cmake -E cmake_link_script
> >> > CMakeFiles/cmTryCompileExec1997038117.dir/link.txt --verbose=1
> >> > CMakeFiles/cmTryCompileExec1997038117.dir/CheckFunctionExists.c.o -o
> >> > cmTryCompileExec1997038117 -rdynamic -lm
> >> > CMakeFiles/cmTryCompileExec1997038117.dir/CheckFunctionExists.c.o: In
> >> > function `main':
> >> > CheckFunctionExists.c:(.text+0x15): undefined reference to `strrstr'
> >> > collect2: ld gab 1 als Ende-Status zurück
> >> > gmake[1]: Leaving directory
> >> > gmake[1]: *** [cmTryCompileExec1997038117] Fehler 1
> >> > gmake: *** [cmTryCompileExec1997038117/fast] Fehler 2
> >> > ... (this is similarly repeated for the other functions)
> >> > Thanks, Michael
> >> > 2016-06-24 10:09 GMT+02:00 thomas bonfort <thomas.bonfort at gmail.com>:
> >> >> Try deleting everything in the build directory and starting again,
> >> >> might be a cmake cache problem...
> >> >> On 24 June 2016 at 10:07, Michael Schulz <mandschulz at googlemail.com>
> >> >> wrote:
> >> >> > Hi,
> >> >> > I have exactly the same issue here. Trying to build mapserver on
> SLES
> >> >> > 11
> >> >> > SP4, I have disabled harfbuzz and fribidi:
> >> >> > cmake .. \
> >> >> > -DCMAKE_PREFIX_PATH=/opt/gdal-trunk \
> >> >> > -DWITH_CLIENT_WFS=ON \
> >> >> > -DWITH_CLIENT_WMS=ON \
> >> >> > -DWITH_CURL=ON \
> >> >> > -DWITH_SOS=ON \
> >> >> > -DWITH_PHP=ON \
> >> >> > -DWITH_PYTHON=ON \
> >> >> > -DWITH_SVGCAIRO=ON \
> >> >> > -DWITH_ORACLESPATIAL=ON \
> >> >> > -DWITH_HARFBUZZ=0 \
> >> >> > -DWITH_FRIBIDI=0 \
> >> >> > -DWITH_FCGI=0 \
> >> >> > >../configure.out.txt
> >> >> > configure.out:
> >> >> > -- Found ORACLE:
> >> >> > -- * RSVG: disabled
> >> >> > -- * ICONV: ENABLED
> >> >> > -- * Mapscripts
> >> >> > -- * PHP: ENABLED
> >> >> > -- * PERL: disabled
> >> >> > -- * RUBY: disabled
> >> >> > -- * JAVA: disabled
> >> >> > -- * C#: disabled
> >> >> > -- Will install files to /usr/local
> >> >> > -- Will install libraries to /usr/local/lib
> >> >> > Is this related to disabling Harfbuzz or Fribidi? I understood that
> >> >> > Harfbuzz
> >> >> > is not needed unless for special languages character rendering?
> >> >> > Thanks, Michael
> >> >> > 2016-06-24 8:36 GMT+02:00 thomas bonfort <thomas.bonfort at gmail.com
> >> >> >> Matthew,
> >> >> >> What configure flags did you use to build harfbuzz? What harfbuzz
> >> >> >> version are you using?
> >> >> >> thomas
> >> >> >> On 21 June 2016 at 20:41, Cechini, Matthew F. (GSFC-423.0)[Science
> >> >> >> Systems & Applications, Inc.] <matthew.f.cechini at nasa.gov> wrote:
> >> >> >> > As it turns out, the issue is Harfbuzz:
> >> >> >> > In the pre-compile checks, I see this:
> >> >> >> > -- checking for module 'harfbuzz>=0.9.18'
> >> >> >> > -- package 'harfbuzz>=0.9.18' not found
> >> >> >> > -- Found HarfBuzz: /usr/local/include/harfbuzz
> >> >> >> > Seems ok, it didn’t find an installed RPM/package, but it finds
> >> >> >> > the
> >> >> >> > directory where I build and installed manually.
> >> >> >> > But the problem then is that there is a missing header file from
> >> >> >> > Harfbuzz:
> >> >> >> > In file included from
> >> >> >> > /home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.c:32:
> >> >> >> > /home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.h:15:20:
> >> >> >> > error:
> >> >> >> > hb-ft.h: No such file or directory
> >> >> >> > /home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.c: In
> >> >> >> > function
> >> >> >> > 'msFreeFontCache':
> >> >> >> > /home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.c:82:
> >> >> >> > warning:
> >> >> >> > implicit declaration of function 'hb_font_destroy'
> >> >> >> > /home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.c:84:
> >> >> >> > warning:
> >> >> >> > implicit declaration of function 'hb_font_funcs_destroy'
> >> >> >> > I see that particular header file in the src directory, from
> which
> >> >> >> > `make
> >> >> >> > install` is run for harfbuzz… but it’s not “installed”. I can’t
> >> >> >> > seem
> >> >> >> > to
> >> >> >> > find an RPM for Centos 6, so building from source seems to be
> the
> >> >> >> > path I
> >> >> >> > have to follow.
> >> >> >> > Matt
> >> >> >> > Matthew Cechini
> >> >> >> > Contractor, Science Systems and Applications, Inc.
> >> >> >> > NASA GIBS Systems/Software Engineer
> >> >> >> > 410.205.6272
> >> >> >> > From: Thomas Gratier <osgeo.mailinglist at gmail.com>
> >> >> >> > Date: Tuesday, June 21, 2016 at 12:30 PM
> >> >> >> > To: Matthew Cechini <matthew.f.cechini at nasa.gov>
> >> >> >> > Cc: "mapserver-users at lists.osgeo.org"
> >> >> >> > <mapserver-users at lists.osgeo.org>
> >> >> >> > Subject: Re: [mapserver-users] Building Mapserver - missing
> >> >> >> > strlcat...
> >> >> >> > methods
> >> >> >> > Hi,
> >> >> >> > "build map server 7.0.1 on linux": distro, architecture?
> >> >> >> > You should look at
> https://github.com/mapserver/mapserver/blob/branch-7-0/.travis.yml
> >> >> >> > to
> >> >> >> > find
> >> >> >> > out more about MapServer deps.
> >> >> >> > Cheers
> >> >> >> > Thomas Gratier
> >> >> >> > 2016-06-20 22:35 GMT+02:00 Cechini, Matthew F.
> >> >> >> > Systems
> >> >> >> > & Applications, Inc.] <matthew.f.cechini at nasa.gov>:
> >> >> >> >> I’m attempting to build map server 7.0.1 on linux and am
> getting
> >> >> >> >> the
> >> >> >> >> following errors. I’m sure I’m missing some dependency… but
> >> >> >> >> google
> >> >> >> >> has
> >> >> >> >> failed me to figure it out. Help?
> >> >> >> >> -- Looking for PQserverVersion in pq - not found
> >> >> >> >> -- Looking for pthread_create - not found
> >> >> >> >> -- Looking for pthread_create in pthreads - not found
> >> >> >> >> Matt
> >> >> >> >> Matthew Cechini
> >> >> >> >> 410.205.6272
> >> >> >> >> _______________________________________________
> >> >> >> >> mapserver-users mailing list
> >> >> >> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> >> >> > Michael Schulz
Michael Schulz
Johann-Sebastian-Bach-Str. 32
79104 Freiburg
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160624/7d0b5729/attachment-0001.html>
